Acer ES1-512 Wistron EA53-BM 14222-1 Schematic
The Wistron EA53-BM-1 motherboard, documented under project code 4PD037010001 and PCB number 14222, is built around the Intel Bay Trail-M CPU platform. The system firmware is stored on a W25Q64FW SPI flash IC. Embedded controller functions are handled by an NPCE985PB KBC. Memory configuration consists of a single DDR3L 1333MHz channel A slot. The charging subsystem is managed by an HPA02224 charger IC, with system power regulation provided by RT6575B, TPS51716, RT9198, and APL5930 DC/DC converters and LDOs. Audio is processed by an ALC2832 HD Audio Codec. Networking is supported by a Realtek RTL8111G LAN IC and a WLAN & BT combo module. A GL850G USB 2.0 hub expands USB connectivity, and a Realtek card reader is integrated. The board revision is A3, dated June 4, 2014.
A: The BIOS SPI flash is a W25Q64FW.
A: The embedded controller is an NPCE985PB.
A: The charging IC is an HPA02224.
Q: What is the memory configuration for this motherboard?
A: The board supports one DDR3L 1333MHz channel A slot.
| Brand | Wistron |
| Project Code | 4PD037010001 |
| Board Number | EA53-BM-1 |
| Revision | A3 |
| Date | Wednesday, June 04, 2014 |
| CPU Platform | Bay Trail-M |
| EC / KBC | NPCE985PB |
| Audio Codec | ALC2832 |
| BIOS / SPI Flash | W25Q64FW |
| Charging IC | HPA02224 |
| Power IC(s) | RT6575B, TPS51716, RT9198, APL5930 |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L 1333MHz Channel A |
| RAM Quantity / Slots | 1 Slot |
| LAN IC | Realtek RTL8111G |
| WiFi / WLAN IC | WLAN & BT comb module |
| Card Reader IC | Realtek |
| USB Hub IC | GL850G |
| PCB Number | 14222 |
| Document Number | EA53-BM-1 |
4PD037010001
EA53-BM-1
Bay Trail-M
NPCE985PB
ALC2832
W25Q64FW
HPA02224
APL5930
RT6575B
RT9198
TPS51716
RTL8111G
GL850G
14222
4PD037010001
EA53-BM-1
Bay Trail-M
NPCE985PB
ALC2832
W25Q64FW
HPA02224
APL5930
RT6575B
RT9198
TPS51716
RTL8111G
GL850G
14222
