acer es1-512 wistron ea53-bm 14222-1 ea53-bm 14222-1 1
The Wistron EA53-BM motherboard, documented under project code 4PD037010001 and board number 14222 revision -163, is built around the Intel Bay Trail-M CPU platform. System memory consists of one DDR3L 1333MHz Channel A slot. The embedded controller is an NPCE985PB, and the BIOS SPI flash is a W25Q64FWSSIG. Audio is handled by an ALC283 codec. The charging architecture utilizes an HPA02224R charger IC, with power regulation provided by RT6575B, TPS51716, RT9198, and APL5930. Networking is supported by a Realtek RTL8111G LAN IC and a WLAN & BT combo module. A GL850G hub IC manages the card reader and USB 2.0 hub functions.
A: The BIOS SPI flash is a W25Q64FWSSIG.
A: The embedded controller is an NPCE985PB.
A: The charger architecture uses an HPA02224R charger IC.
Q: What memory type and configuration does this motherboard support?
A: It supports DDR3L 1333MHz memory in a single Channel A slot.
| Brand | Wistron |
| Model | EA53-BM |
| Project Code | 4PD037010001 |
| Board Number | 14222 |
| Revision | -163 |
| Date | Wednesday, June 04, 2014 |
| Document Number | EA53-BM-1 |
| CPU Platform | Bay Trail-M |
| EC / KBC | NPCE985PB |
| Audio Codec | ALC283 |
| BIOS / SPI Flash | W25Q64FWSSIG |
| Charging IC | HPA02224 |
| Charger Architecture | HPA02224R |
| Power IC(s) | RT6575B, TPS51716, RT9198, APL5930 |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L 1333MHz Channel A |
| RAM Quantity / Slots | 1 Slot |
| Card Reader IC | GL850G |
| USB Hub IC | GL850G |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | WLAN & BT comb module |
4PD037010001
14222
Bay Trail-M
NPCE985PB
ALC283
W25Q64FWSSIG
HPA02224
APL5930
RT6575B
RT9198
TPS51716
DDR3L
GL850G
GL850G
RTL8111G
4PD037010001
14222
Bay Trail-M
NPCE985PB
ALC283
W25Q64FWSSIG
HPA02224
APL5930
RT6575B
RT9198
TPS51716
DDR3L
GL850G
GL850G
RTL8111G
