acer emachines g520 g720 quanta zy6d_rev1a schematic
acer emachines g520 g720=1=quanta zy6d_rev1a.pdf
This Quanta ZY6D motherboard schematic, dated August 28, 2008, is designed for the Penryn 479uFCPGA CPU platform paired with an ICH9M southbridge. The system block diagram confirms the use of an EC/KBC identified as WPC8769LDG. Clock generation is handled by either an ICS9LPRS365BGLFT or an SLG8SP512K05 clock generator. Audio is managed by an ALC268 & 888 audio codec, and networking is provided by a Broadcom LAN IC. Memory architecture supports Dual Channel DDR2 or DDR3 configurations across two SO-DIMM slots. The schematic also references a SPI ROM for BIOS storage and a thermal sensor.
Q: What EC/KBC is used on this Quanta ZY6D motherboard?
A: The EC/KBC is a WPC8769LDG.
Q: What clock generator ICs are used on this motherboard?
A: The schematic lists two clock generator options: ICS9LPRS365BGLFT and SLG8SP512K05.
Q: What memory configurations does this motherboard support?
A: The motherboard supports Dual Channel DDR2 or DDR3 memory across two SO-DIMM slots.
| Project Code | ZY6D |
| Date | Thursday, August 28, 2008 |
| CPU Platform | Penryn 479uFCPGA |
| PCH / Southbridge | ICH9M |
| EC / KBC | WPC8769LDG |
| Clock Generator | ICS9LPRS365BGLFT |
| Clock Generator | SLG8SP512K05 |
| Audio Codec | ALC268 & 888 |
| LAN IC | BROADCOM |
| RAM Architecture | Dual Channel DDR2 |
| RAM Architecture | DDR3 |
| RAM Quantity / Slots | SO-DIMM 0, SO-DIMM 1 |
| Thermal Sensor | TSEL |
| SPI ROM | SPI ROM |
