acer emachines d520-d720-e520-e720 ls-4391p_jawd0_rev 1.0 pwr board schematic
compal ls-4391p_jawd0_rev 1.0 pwr board.pdf
This Compal Electronics schematic, dated June 20, 2008, documents the PWR/B S4391 power board, identified by project code 4059RDB and board number JAWD0LS-4391P at revision 1.0. The board is a dedicated power button and LED interface, featuring an ON/OFF button, power LED, and suspend LED indicators. The design incorporates a 5-pin FFC connector (ZZZ2FFC45) and a 6-pin header (JP1 ACES_85201-0605) for system interconnection. LED indicators include an amber LED (HT-191UD) and a yellow/green LED (HT-191UYG-DT) in 0603 packages. The board uses SOT23 diodes (PSOT24C) and 0402 resistors for signal conditioning. This power board schematic provides the essential power control and status indication interface for the Compal 4059RDB platform.
Q: What is the board number for this Compal power board?
A: The board number is JAWD0LS-4391P at revision 1.0.
Q: What is the project code and document number for this schematic?
A: The project code and document number are both 4059RDB.
Q: What type of connectors are used on this power board?
A: The board uses a 5-pin FFC connector (ZZZ2FFC45) and a 6-pin header (JP1 ACES_85201-0605).
| Project Code | 4059RDB |
| Board Number | JAWD0LS-4391P |
| Date | 2008/06/20 |
| Model Name | PWR/B S4391 |
| Document Number | 4059RDB |
