acer aspire e5-575 e5-575g e5-575t zaa serials skl ult_ironman sk quanta zaa schematic
zaa serials skl ult_ironman_sk quanta.pdf
This Quanta ZAA reference design, documented under number 1A148 dated February 5, 2016, is built around the SKL ULT 15W platform with an integrated PCH and an IMC MCP 1356-pin package housing the GT3e iGPU. The system memory architecture consists of dual-channel DDR4 via two DDR4-SODIMM sockets. The embedded controller is an IT8987, and the audio subsystem is handled by an ALC255 codec. Power management is distributed across multiple ICs including the BQ24780S battery charger, RT8237CZQW, TPS51225R, ISL95859HRTZ-T, ISL95808, RT8068AZQW, and UP1658RQKF. The SPI ROM is configured as 8M+4M. Connectivity and peripheral support include an RTL8411 card reader, a LAN_CRD_COMBO controller, and a PTN3366B HDMI level shifter.
A: The embedded controller is an IT8987.
Q: What is the BIOS/SPI flash configuration?
A: The SPI ROM is configured as 8M+4M.
A: The battery charger IC is a BQ24780S.
A: The system supports dual-channel DDR4 via two DDR4-SODIMM sockets (CHA and CHB).
| Project Code | ZAA |
| Document Number | 1A148 |
| Date | Friday, February 05, 2016 |
| CPU Platform | SKL ULT 15W |
| Platform Alias | KBL15@ : For Key/B 15" KBL17@ : For Key/B 17" KBL@ : Key/B backlight |
| PCH / Southbridge | Integrated PCH |
| GPU Type | iGPU / GT3e |
| Graphics Architecture | IMC MCP 1356 pins |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 8M+4M |
| Charging IC | BQ24780S |
| Power IC(s) | RT8237CZQW, TPS51225R, ISL95859HRTZ-T, ISL95808, RT8068AZQW, UP1658RQKF |
| RAM Type | Dual Channel DDR4 |
| RAM Architecture | DDR4-SODIMM CHA, DDR4-SODIMM CHB |
| Card Reader IC | RTL8411 |
| LAN IC | LAN_CRD_COMBO |
| HDMI Level Shifter | PTN3366B |
Skylake-ULT
B Backlight
Kaby Lake
GT3e
IMC MCP 1356 pins
IT8987
ALC255
BQ24780S
ISL95808
ISL95859HRTZ-T
RT8068AZQW
RT8237CZQW
TPS51225R
UP1658RQKF
RTL8411
PTN3366B
Skylake-ULT
B Backlight
Kaby Lake
GT3e
IMC MCP 1356 pins
IT8987
ALC255
BQ24780S
ISL95808
ISL95859HRTZ-T
RT8068AZQW
RT8237CZQW
TPS51225R
UP1658RQKF
RTL8411
PTN3366B
