acer aspire e5-575 e5-575g e5-575t zaaa serials skylake-u captain_sk quanta schematic
zaaa serials skylake-u captain_sk quanta.pdf
This Quanta Computer Inc. ZAAS project motherboard is built around the Intel Skylake ULT 15W CPU platform with integrated PCH. The system utilizes dual-channel DDR4 memory via SODIMM slots. Graphics are handled by a GT3e IMCMCP GPU in a 1356-pin package with GDDR5 memory at 1.35V. The BIOS is stored on an SPI ROM with a combined 8M+4M capacity. The embedded controller is an IT8987, and the audio codec is an ALC255. Power management is handled by a BQ24780S battery charger, an RT6575AGQW for +3V/+5V rails, an ISL95859HRTZ-T for VCCORE/VCCSA/VCCGT, and an RT8068AZQW for +1.05V_GFX. Networking is provided by an RTL8411B 10/100/1000 LAN controller. The board also features a G5335QT2U card reader and a PTN3366BSP HDMI level shifter.
A: The BIOS is stored on an SPI ROM with a combined capacity of 8M+4M.
A: The embedded controller is an IT8987.
A: The battery charger IC is a BQ24780S.
A: The board supports dual-channel DDR4 memory using DDR4-SODIMM slots.
| Project Code | ZAAS |
| Date | Monday, March 28, 2016 |
| CPU Platform | SkyLake-U SYSTEM BLOCK DIAGRAM / SKL_ULT 15W |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 8M+4M |
| Charging IC | BQ24780S |
| Power IC(s) | RT6575AGQW, ISL95859HRTZ-T, RT8068AZQW |
| RAM Architecture | Dual Channel DDR4, DDR4-SODIMM |
| LAN IC | RTL8411B |
| Card Reader IC | G5335QT2U |
| HDMI Level Shifter | PTN3366BSP |
| GPU Type | GT3e IMCMCP 1356pins |
| Graphics Architecture | GDDR5/ 1.35V |
Skylake
IT8987
ALC255
BQ24780S
ISL95859HRTZ-T
RT6575AGQW
RT8068AZQW
RTL8411B
G5335QT2U
PTN3366BSP
GDDR5/ 1.35V
Skylake
IT8987
ALC255
BQ24780S
ISL95859HRTZ-T
RT6575AGQW
RT8068AZQW
RTL8411B
G5335QT2U
PTN3366BSP
GDDR5/ 1.35V
