acer aspire 5520 la-3581p icw50 r00 1116
This Compal LA-4381P revision 0.0 motherboard, project code ANRKAL0000(KAL00), is built on the AMD S1g2 platform supporting Turion64 x2 TLxx or Sempron processors. The chipset consists of an ATI-RS780M GPU and an ATI-SB700 southbridge. System memory is provided by two DDR2 SO-DIMM slots configured for dual-channel operation up to 800MHz. The embedded controller is an ENE KB926, and the audio subsystem is handled by an ALC269 codec. SPI BIOS flash is used for firmware storage. Networking is provided by a Broadcom BCM5784M LAN controller, and a Ricoh R5C833C card reader controller is present. The clock generator is an SLG8SP626VTR or ICS9LPRS476BKLFT, and thermal monitoring is managed by an ADM1032ARM sensor. The PCB is identified as ZZZ115W_PCB.
A: The embedded controller is an ENE KB926.
Q: What is the audio codec on this motherboard?
A: The audio codec is an ALC269.
Q: What LAN controller is used on this motherboard?
A: The LAN controller is a Broadcom BCM5784M.
Q: What card reader controller is present on this motherboard?
A: The card reader controller is a Ricoh R5C833C.
Q: What is the clock generator on this motherboard?
A: The clock generator is an SLG8SP626VTR or ICS9LPRS476BKLFT.
| Project Code | ANRKAL0000(KAL00) |
| Board Number | LA-4381P |
| Revision | 0.0 |
| Date | Wednesday, January 16, 2008 |
| CPU Platform | AMD S1g2 |
| CPU Model | Turion64 x2 TLxx / Sempron |
| PCH / Southbridge | ATI-SB700 |
| GPU Type | ATI-RS780M |
| EC / KBC | ENE KB926 |
| Audio Codec | ALC269 |
| BIOS / SPI Flash | SPI BIOS |
| RAM Type | DDR-2 |
| RAM Architecture | Daul Channel DDR-2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| LAN IC | Broadcom BCM5784M |
| Card Reader IC | Ricoh R5C833C |
| Clock Generator | SLG8SP626VTR/ICS9LPRS476BKLFT |
| Thermal Sensor | ADM1032ARM |
| PCB Number | ZZZ115W_PCB |
ANRKAL0000
KAL00
LA-4381P
S1G2
SB700
RS780M
KB926
ALC269
DDR 2
BCM5784M
RICOH R5C833C
ICS9LPRS476BKLFT
SLG8SP626VTR
ADM1032ARM
ZZZ115W_PCB
ANRKAL0000
KAL00
LA-4381P
S1G2
SB700
RS780M
KB926
ALC269
DDR 2
BCM5784M
RICOH R5C833C
ICS9LPRS476BKLFT
SLG8SP626VTR
ADM1032ARM
ZZZ115W_PCB
