Dell G15 5520 HDK50 LA-L659P Rev 1.0 Schematic
This Compal LA-L651P schematic, revision 0.2, dated 2021.11.10, documents an ADL-P platform motherboard. The board is identified by the PCB number ZZZPCB 3LP LA-L651P REV0 M/B SAXIOM_PCB@DAB0009U000. The design supports N18P/GN20P GPU types with GN20P0/GN20P1 SKU variants. The embedded controller features EC G3 Flash Sharing capability, indicating programmable EC firmware support. The schematic includes provisions for CNVi support, VRAM SKUs (VS8GR3/VM8GR3/VH8GR1), and BBY support. The document is classified as Compal Secret Data.
Q: What is the board number and revision of this schematic?
A: The board number is LA-L651P, revision 0.2.
Q: What CPU platform does this motherboard use?
A: This motherboard is based on the ADL-P (Alder Lake-P) platform.
A: Yes, the schematic indicates EC G3 Flash Sharing, which supports EC firmware programming.
Q: What GPU configurations are supported on this motherboard?
A: The schematic supports N18P/GN20P GPU types with GN20P0/GN20P1 SKU variants.
| Project Code | LA-L651P |
| Board Number | LA-L651P |
| Revision | 0.2 |
| Date | 2021.11.10 |
| CPU Platform | ADL-P |
| Document Number | LA-L651P |
| PCB Number | la-l651p-rev0-m-b-saxiom-pcb-dab0009u000/"]ZZZPCB 3LP LA-L651P REV0 M/B SAXIOM_PCB@DAB0009U000[/URL] |
| GPU Type | N18P/GN20P |
| Graphics Architecture | GN20P0/GN20P1 |
| EC / KBC | EC G3 Flash Sharing |
| EC/KBC Programmable | EC G3 Flash Sharing |
