toshiba satellite 1200 compal_la-1441_rev 0.2 schematic
toshiba satellite 1200=1=compal_la-1441_rev 0.2.pdf
This Compal LA-1441 REV 0.2 motherboard schematic, dated March 6, 2002, details a platform built around a uFCBGA/uFCPGA Coppermine-T or Tualatin CPU with the Almador-M chipset. The system integrates an NS PC87591 embedded controller, a CS4299 AC'97 audio codec, and an LPC47N227 Super I/O. Memory architecture consists of two SO-DIMM slots for SDRAM. The board features an RTL8100-L LAN controller, a Mini PCI socket for wireless connectivity, and a PCI1420 CardBus controller. Thermal management is handled by a MAX1617MEE sensor. The BIOS is stored in an EEPROM (24C16/02), and the clock generation is managed by an ICS9250-38.
A: The board number is LA-1441, and the revision is REV 0.2.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an NS PC87591.
Q: What type of BIOS flash memory is used?
A: The BIOS is stored in an EEPROM, specifically a 24C16 or 24C02.
A: The memory architecture uses SDRAM in two SO-DIMM slots.
| Model | LA-1441 |
| Board Number | LA-1441 |
| Revision | REV 0.2 |
| Date | Wednesday, March 06, 2002 |
| CPU Platform | uFCBGA/uFCPGA Coppermine-T or Tualatin CPU |
| GPU Type | Almador-M GMCH-M |
| EC / KBC | NS PC87591 |
| Audio Codec | CS4299 |
| BIOS / SPI Flash | EEPROM(24C16/02) |
| Charging IC | Charger |
| RAM Type | SDRAM |
| RAM Quantity / Slots | SO-DIMM * 2 |
| Thermal Sensor | MAX1617MEE |
| LAN IC | RTL8100-L |
| WiFi / WLAN IC | Mini PCI Socket |
| Card Reader IC | PCI1420 |
| Super I/O | LPC47N227 |
| Clock Generator | ICS9250-38 |
| Document Number | LA-1441 |
