Schematic Tongfang PF4WN2F PF4WN3F PF5WN2G GK5CN3X MB Schematic
BrandVANDERP
ModelPF4WN3F
Project NamePF4WN3F
Drawing NameBAT_3S1P_PF4WN3F
Date11/22/18
RevisionREV.
Part Number12345678ABCD12345678ABCD27.42235.5
This document is a battery pack drawing for the VANDERP PF4WN3F project, dated November 22, 2018. The drawing specifies a 13-pin wire-to-board battery connector with defined pin functions including BAT+, enable to ground, battery clock and data lines, a 3.3V ROM_POR VCC supply, and a battery temperature sense pin. The battery configuration is 3S1P, indicating three cells in series and one in parallel. The drawing includes dimensional tolerances and material specifications for the battery assembly.
Q: What is the battery connector pinout for the PF4WN3F?
A: Pins 1-4 are BAT+, pin 5 is Enable to GND, pin 6 is BAT_CLK, pin 7 is BAT_DAT, pin 8 is ROM_POR VCC 3.3V, pin 9 is BATT_TEMP, and pins 10-13 are BAT-.
Q: What is the battery configuration for the PF4WN3F?
A: The battery is configured as 3S1P, meaning three cells in series and one cell in parallel.
DateThursday, September 27, 2018
Document Number5544332211DDCCBBAALID_DB#+3.3VATitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3FTitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3FTitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3F
Hall SensorBDPFWN3F
Switch ICAPX8132AI-TRG
ConnectorFFC,4P,P1.0,51601-0040M-001,ACEcon_ffc-4tb10_51601-0040m_aces
This document, dated Thursday, September 27, 2018, references a Hall Sensor BDPFWN3F and a Switch IC APX8132AI-TRG. The connector is specified as FFC,4P,P1.0,51601-0040M-001,ACEcon_ffc-4tb10_51601-0040m_aces. The document number is 5544332211DDCCBBAALID_DB#+3.3VATitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3FTitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3FTitleSizeDocument NumberRevDate:SheetofAB11Thursday, September 27, 2018Hall Sensor BDPFWN3F.
Q: What Hall Sensor is referenced in this document?
A: BDPFWN3F.
Q: What Switch IC is used?
A: APX8132AI-TRG.
Q: What connector type is specified?
A: FFC,4P,P1.0,51601-0040M-001,ACEcon_ffc-4tb10_51601-0040m_aces.
BrandGS4CP5FA
ModelPF4WN3F
Project CodePF4WN3F
Board NumberGS4CP5FA
RevisionA
DateWednesday, November 21, 2018
CPU PlatformWHL-H+MX150
Document NumberPF4WN3F
This motherboard, identified by project code PF4WN3F and board number GS4CP5FA, is based on the WHL-H+MX150 platform. The schematic document is dated Wednesday, November 21, 2018, and carries revision A. The document number is PF4WN3F.
Q: What is the board number for this motherboard?
A: The board number is GS4CP5FA.
Q: What is the project code for this motherboard?
A: The project code is PF4WN3F.
Q: What CPU platform does this motherboard use?
A: The CPU platform is WHL-H+MX150.
No technical data could be extracted from the provided source material.
No FAQ items could be generated from the provided source material.
Document NumberB22
DateWednesday, November 28, 2018
EC / KBCDSP-AS568
EC/KBC PackageP48
Touch ICBF5131A
Touch ICBF5132A
This motherboard, documented under Document Number B22 dated Wednesday, November 28, 2018, utilizes the DSP-AS568 EC/KBC controller in a P48 package. The design incorporates BF5131A and BF5132A touch ICs for touch input processing. The schematic includes a 6-pin FFC connector (AFC34-S06FCA) for touch panel interface, along with ESD protection via the ESD5302N. Power rails include +3.3V_TP and +1.8V for touch subsystem operation. The EC/KBC features SPI and SQI interfaces for flash communication, along with SWD/SWCLK debug interfaces.
A: The DSP-AS568 in a P48 package.
Q: What touch ICs are present on this motherboard?
A: The BF5131A and BF5132A touch ICs are used.
Document NumberPF4WN3F1.SW/CN
DateMonday, November 19, 2018
RevisionAB13
This document, identified as PF4WN3F1.SW/CN, is a power button and LED sub-board schematic dated Monday, November 19, 2018, with revision AB13. The board includes a power button connector (CNPWR1) specified as an FFC, 12P, SMT, P0.5, 50696-0120M-002, ACECON_FFC_12R05_50696_0120M_ACES. The LED section, dated Friday, November 16, 2018, with revision AB23, uses LED21 and LED22, both LED_WHITE_4_RNM_RNM, with associated resistors R23 and R22 at 300-04. The revision history, dated Friday, November 16, 2018, with revision AA33, documents footprint modifications to SW1, SW2, H1-H4, and the deletion of H5-H8, SW2, and LED.
Q: What is the document number for this sub-board schematic?
A: The document number is PF4WN3F1.SW/CN.
Q: What is the revision and date of the power button section?
A: The power button section is revision AB13, dated Monday, November 19, 2018.
Q: What type of connector is used for the power button?
A: The power button connector (CNPWR1) is an FFC, 12P, SMT, P0.5, 50696-0120M-002, ACECON_FFC_12R05_50696_0120M_ACES.
BrandTongFang Inc.
ModelAGK5CN3X MB
Motherboard ManufacturerTongFang Inc.
Project CodePF4WN3F
Board NumberAGK5CN3X MB
RevisionC145
DateTuesday, November 27, 2018
CPU PlatformCoffee Lake - H
PCH / SouthbridgeHM370
GPU TypeN17E-G1
Graphics Architecture1060 3GB or 6GB
EC / KBCIT8528E
EC/KBC Package128 Pin LQFP
Audio CodecALC269Q-VC3-GR
BIOS / SPI Flash16MB
Charging ICBQ24781
Charger ArchitectureBATTERY CHARGER
Power IC(s)APW8713A, APW8804, APW8715QBI-TRG, APL3523QBI-TRG, NB687, MP2949AGQKT, MP86901B, MP86901A, uP1642T, uP1666Q, RT8237
RAM TypeDDR4 2400MHz (NON ECC)
RAM Architecture2*DDR4 SO-DIMM
RAM Quantity / Slots2
LAN ICRTL8118AG
WiFi / WLAN ICRTL8111G
Card Reader ICrts5170-gr/"]RTS5170-GR[/URL]
The TongFang Inc. AGK5CN3X MB (Project Code PF4WN3F, Revision C145, dated November 27, 2018) is built on the Intel Coffee Lake-H platform with an HM370 PCH. The motherboard supports DDR4 2400MHz non-ECC memory via two SO-DIMM slots. Graphics are handled by an N17E-G1 GPU with 1060 3GB or 6GB GDDR5 memory. The embedded controller is an IT8528E in a 128-pin LQFP package. The system BIOS is stored on a 16MB SPI flash ROM. Audio is provided by a Realtek ALC269Q-VC3-GR codec. The charging architecture uses a BQ24781 battery charger IC. Power management is handled by a suite of ICs including APW8713A, APW8804, APW8715QBI-TRG, APL3523QBI-TRG, NB687, MP2949AGQKT, MP86901B, MP86901A, uP1642T, uP1666Q, and RT8237. Networking includes a Realtek RTL8118AG LAN controller and an RTL8111G WLAN IC. A Realtek RTS5170-GR card reader is also present.
Q: What is the EC/KBC used on this motherboard?
A: The embedded controller is an IT8528E in a 128-pin LQFP package.
A: The charging IC is a BQ24781 battery charger.
A: The BIOS is stored on a 16MB SPI flash ROM.
Q: What is the GPU configuration?
A: The GPU is an N17E-G1 with 1060 3GB or 6GB GDDR5 memory.
BrandTongFang Inc.
ModelAGK5CN3X MB
Project CodePF4WN3F
RevisionC145
DateThursday, November 29, 2018
GPU TypeN17E-G1
Graphics ArchitectureGDDR5 X6 (1060) 1060 3GB or 6GB
EC / KBCIT8528E
BIOS / SPI FlashFlash Rom 8 Pin M-SOP
BIOS Flash Capacity16MB
Charging ICBQ24781
Charger ArchitectureBATTERY CHARGER IC EC CONTROLER
RAM ArchitectureSO-DIMM 260 Pin
LAN ICRTL8118AG
The TongFang Inc. AGK5CN3X MB motherboard, project code PF4WN3F, revision C145, dated November 29, 2018, is built on the Intel Coffee Lake-H platform with an HM370 PCH. Graphics are handled by an N17E-G1 GPU with GDDR5 memory configurable as 1060 3GB or 6GB. The embedded controller is an IT8528E in a 128-pin LQFP package. System audio is provided by an ALC269Q-VC3-GR codec. The BIOS is stored on a 16MB SPI Flash ROM in an 8-pin M-SOP package. Charging is managed by a BQ24781 IC under EC control. Memory consists of two DDR4 2400MHz non-ECC SO-DIMM 260-pin slots. The board integrates an RTS5170-GR card reader, an RTL8118AG LAN IC, and an RTL8111G WLAN IC.
A: The BIOS is a 16MB SPI Flash ROM in an 8-pin M-SOP package.
Q: What EC/KBC chip is used on this motherboard?
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a BQ24781, controlled by the EC.
Q: What is the GPU configuration on this motherboard?
A: The GPU is an N17E-G1 with GDDR5 memory, configurable as 1060 3GB or 6GB.
BrandPF4WN3F
Project CodePF4WN3F
PlatformWHL-H+MX150
Document NumberGS4CP5FA
RevisionA
GPU TypeMX150
Graphics ArchitectureMX150
Card Reader ICRTS5170
Card Reader ICRT3506
LAN ICGST5009-LF
This PF4WN3F motherboard is built on the WHL-H+MX150 platform, integrating an MX150 discrete GPU. The board is documented under document number GS4CP5FA with revision A, dated Wednesday, November 28, 2018. The LAN subsystem is managed by a GST5009-LF controller. For storage expansion, the board features a card reader subsystem utilizing both RTS5170 and RT3506 controllers for SD card interface support.
Q: What is the platform and GPU configuration of this motherboard?
A: This motherboard uses the WHL-H+MX150 platform with an integrated MX150 discrete GPU.
Q: What LAN controller is used on this motherboard?
A: The LAN subsystem is managed by a GST5009-LF controller.
Q: What card reader controllers are present on this motherboard?
A: The card reader subsystem uses both RTS5170 and RT3506 controllers.
  • Tongfang PF4WN2F PF4WN3F PF5WN2G GK5CN3X MB Schematic.zip
