Tongfang GX502LXS Rev 2.1 Schematic
This ASUSTeK GX502GX motherboard, revision R1.2 dated February 21, 2020, is built on the Coffeelake H platform with a CNL PCH-H HM370 southbridge. The system supports DDR4 memory via one SO-DIMM slot and one on-board memory configuration. Graphics processing is handled by an NVIDIA N18E-G3/G2/G1/G0 GPU paired with GDDR6 VRAM. The embedded controller is an IT8225, with an additional EC IT1525VG-128/CX for keyboard and touchpad management. Audio is provided by a Realtek ALC3288-CG codec. Networking includes an RTL8125-CG Gigabit LAN controller and an AX201.D2WG.NV WiFi/BT module. The board features a dedicated SPI ROM for BIOS storage, a slave charger architecture, and a TS3DV642A0RUAR HDMI level shifter. Additional connectivity is supported by a GL9901AS14151 USB redriver and an RTS5170 card reader controller.
Q: What EC/KBC controllers are used on this motherboard?
A: The motherboard uses an IT8225 EC/KBC controller and an EC IT1525VG-128/CX for keyboard and touchpad interface.
A: The board supports DDR4 memory with one SO-DIMM slot and one on-board memory configuration.
A: The audio codec is a Realtek ALC3288-CG.
Q: What LAN and WiFi controllers are present?
A: The LAN controller is an RTL8125-CG, and the WiFi/BT module is an AX201.D2WG.NV.
Q: What is the GPU configuration on this motherboard?
A: The GPU is an NVIDIA N18E-G3/G2/G1/G0 with GDDR6 VRAM.
| Brand | ASUSTeK COMPUTER INC. |
| Model | GX502GX |
| Motherboard Manufacturer | ASUSTeK COMPUTER INC. |
| Project Code | GX502 |
| Revision | R1.2 |
| Date | Friday, February 21, 2020 |
| CPU Platform | Coffeelake H-Processor (H62 / 45W) |
| PCH / Southbridge | CNL PCH-H HM370 |
| GPU Type | NVIDIA N18E-G3/G2/G1/G0 |
| Graphics Architecture | GDDR6 VRAM (256Mbx32)*8 |
| EC / KBC | IT8225 |
| EC/KBC Programmable | EC IT1525VG-128/CX |
| Audio Codec | Realtek ALC3288-CG |
| BIOS / SPI Flash | SPI ROM |
| Charging IC | Charger |
| Charger Architecture | SLAVE CHARGER |
| RAM Architecture | SO-DIMM X1 / On Board Memory X1 |
| LAN IC | RTL8125-CG |
| WiFi / WLAN IC | AX201.D2WG.NV |
| Card Reader IC | RTS5170 |
| USB Hub IC | GL9901AS14151 |
| HDMI Level Shifter | TS3DV642A0RUAR |
GX502
Coffee Lake-H
HM370
N18E-G0
N18E-G1
N18E-G2
N18E-G3
IT8225
IT1525VG-128/CX
ALC3288-CG
RTL8125-CG
AX201.D2WG.NV
GL9901AS14151
TS3DV642A0RUAR
GX502
Coffee Lake-H
HM370
N18E-G0
N18E-G1
N18E-G2
N18E-G3
IT8225
IT1525VG-128/CX
ALC3288-CG
RTL8125-CG
AX201.D2WG.NV
GL9901AS14151
TS3DV642A0RUAR
