sony vgn-nr series foxconn m720 mbx-182_rev1.0 schematic
sony vgn-nr seri=1=foxconn m720 mbx-182_crestline gm block diagram_rev1.0.pdf
The Foxconn M720 Main Board (Revision 1.0, dated July 18, 2007) is built around the Intel Merom CPU platform using a Micro-FCBGA-478 socket. The graphics subsystem is based on the Intel 965GM (Crestline) GPU, paired with an ICH8-M southbridge. System memory consists of two SO-DIMM slots supporting DDR(II) at 667 MHz. The embedded controller and keyboard controller are handled by an ENE KB3910SF. Audio is managed by a Realtek ALC262 codec with a TPA6019A4 amplifier. Networking is provided by a Marvell 88E8039 10/100 Ethernet controller. The board includes a 1MB Flash BIOS, an ICS9LPR358YGLF clock generator, and a TI PCI8402ZHK card reader controller. Thermal monitoring is handled by a G781-1P8f sensor for the CPU/GMCH and a G751-2P1f sensor for the DDR modules. The charging IC is an ISL6262A.
A: The BIOS flash capacity is 1MB.
A: The EC/KBC is an ENE KB3910SF.
A: The charging IC is an ISL6262A.
A: The LAN IC is a Marvell 88E8039.
A: The audio codec is a Realtek ALC262, and the audio amplifier is a TPA6019A4.
| Brand | Foxconn |
| Motherboard Manufacturer | HON HAI Precision Ind. Co., Ltd. / Foxconn |
| Project Code | M720 |
| Board Number | M720 Main Board |
| Date | Wednesday, July 18, 2007 |
| CPU Platform | Merom |
| CPU Socket | Micro-FCBGA-478 (478-pin socket P) |
| GPU Type | Intel 965GM |
| Graphics Architecture | Crestline |
| EC / KBC | ENE KB3910SF |
| Audio Codec | ALC262 |
| BIOS / SPI Flash | Flash BIOS |
| BIOS Flash Capacity | 1MB |
| Charging IC | ISL6262A |
| RAM Type | DDR(II) |
| RAM Architecture | SO-DIMM 667 MHz |
| LAN IC | Marvell 88E8039 |
| WiFi / WLAN IC | Mini-Card PCIE |
| Card Reader IC | TI PCI8402ZHK |
| Clock Generator | ICS9LPR358YGLF |
| Audio Amplifier | TPA6019A4 |
| Document Number | M720-1-01 |
M720
M720 MAIN BOARD
Merom
MICRO-FCBGA-478 478-PIN P
ICH8
965GM
Crestline
KB3910SF
ALC262
ISL6262A
88E8039
PCI8402ZHK
ICS9LPR358YGLF
TPA6019A4
M720
M720 MAIN BOARD
Merom
ICH8
965GM
Crestline
KB3910SF
ALC262
ISL6262A
88E8039
PCI8402ZHK
ICS9LPR358YGLF
TPA6019A4
