sony vaio vgn-bx quanta_wk1_rev2a schematic
sony vaio vgn-bx =1=quanta_wk1_rev2a.pdf
This Quanta WK1 Main Board, dated December 27, 2006, is built around the Intel Merom CPU platform using a 478-pin micro FC-PGA socket, paired with an ICH8-M southbridge. The board features an ATI M71 discrete GPU and supports two unbuffered DDRII 533/667 SO-DIMM slots. System management is handled by a WPC8763L EC/KBC, with an SST 39SF020A BIOS flash IC. Audio is provided by an ALC262 codec, while networking includes a Marvell 8055 GbE LAN controller and an Intel 3945 WLAN module. The clocking solution is an ICS9LPR336 generator. Additional I/O is supported by a JMB362 card reader controller and a CY7C65640 USB hub IC. The charging circuit utilizes a TI-TPA6011A4, and thermal monitoring is managed by an ST Micro LIS3LV02DL sensor.
A: The EC/KBC is a WPC8763L.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS flash IC is an SST 39SF020A.
A: The board uses an ATI M71 discrete GPU.
A: The board supports two unbuffered DDRII 533/667 SO-DIMM slots.
| Brand | QUANTA |
| Board Number | WK1 Main Board |
| Date | Wednesday, December 27, 2006 |
| CPU Platform | Merom |
| CPU Socket | 478 PIN (micro FC-PGA) |
| GPU Type | ATI |
| dGPU Chip Number | M71 |
| EC / KBC | WPC8763L |
| Audio Codec | ALC262 |
| BIOS / SPI Flash | SST 39SF020A |
| Charging IC | TI-TPA6011A4 |
| RAM Type | DDRII 533/667 |
| RAM Architecture | UNBUFFERED |
| Card Reader IC | JMB362 |
| USB Hub IC | CY7C65640 |
| LAN IC | Marvell 8055 |
| WiFi / WLAN IC | Intel 3945 |
| Clock Generator | ICS9LPR336 |
| Thermal Sensor | ST Micro LIS3LV02DL |
WK1 MAIN BOARD
Merom
478 Micro Fc-pga
ICH8
M71
WPC8763L
ALC262
39SF020A
TPA6011A4
JMB362
CY7C65640
8055
3945
ICS9LPR336
ST MICRO LIS3LV02DL
WK1 MAIN BOARD
Merom
478 Micro Fc-pga
ICH8
M71
WPC8763L
ALC262
39SF020A
TPA6011A4
JMB362
CY7C65640
8055
3945
ICS9LPR336
ST MICRO LIS3LV02DL
