Schematic sony vaio vpc-eb foxconn m960 m970 l model mbx-223 revsa schematic
sony vaio vpc-eb foxconn m960 m970 l model_mbx-223_revsa schematic
sony vaio vpc-eb=1=foxconn m960 m970 l model_mbx-223_revsa.pdf
BrandFoxconn
ModelM960 & M970 L Model
Motherboard ManufacturerHON HAI Precision Ind. Co., Ltd. / Foxconn
Project CodeM960 & M970 L Model
Board Number1P-0099J00-60SB (IRIS MB)
RevisionA3173
DateThursday, December 24, 2009
CPU PlatformCalpella Platform UMA Graphic
CPU ModelArrandale Processor
CPU SocketMicro-FCPGA-989 (989-pin rPGA socket)
PCH / SouthbridgeIbex Peak-M (HM55)
GPU Typeuma-graphic/"]UMA Graphic[/URL]
Graphics ArchitectureUMA
EC / KBCWinbond NPCE783L
Audio CodecRealtek ALC269
BIOS / SPI FlashFlash BIOS 1M bit x1 SPI
BIOS Flash Capacity32M bit X 1
Charging ICBQ24753
Charger ArchitectureADC_IN
Power IC(s)MAX17030, TPS51218, SN0608098, MAX17028
RAM TypeDDR(III)
RAM ArchitectureSO-DIMM 0, SO-DIMM 1
RAM Quantity / Slots2
Thermal SensorG781-1
Card Reader ICRicoh R5U231
LAN ICMarvell 88E8059
WiFi / WLAN ICMini-PCIE Card (WLAN)
This Foxconn M960 & M970 L Model motherboard, documented under board number 1P-0099J00-60SB (IRIS MB) with revision A3173 dated December 24, 2009, is built on the Intel Calpella Platform with UMA graphics. The platform utilizes an Intel Arrandale processor in a Micro-FCPGA-989 socket paired with the Ibex Peak-M (HM55) PCH. System memory consists of two DDR3 SO-DIMM slots supporting 800/1066 MHz modules. The embedded controller is a Winbond NPCE783L, and the audio subsystem is handled by a Realtek ALC269 codec. The BIOS is stored on a 32Mbit SPI flash ROM. Power management is handled by a BQ24753 charger IC, with system DC/DC conversion provided by TPS51218, MAX17030, MAX17028, and SN0608098 regulators. Networking is provided by a Marvell 88E8059 Gigabit Ethernet controller, and a Ricoh R5U231 card reader supports MS Duo and SD Card formats.
A: The schematic references a 32M bit x1 SPI Flash BIOS ROM.
A: The embedded controller is a Winbond NPCE783L.
A: The charging IC is a BQ24753.
Q: What is the memory configuration?
A: The motherboard supports two DDR3 SO-DIMM slots at 800/1066 MHz.
  • Sony Vaio VPC-EB=1=Foxconn M960 M970 L Model_MBX-223_RevSA.zip
