sony quanta gc8 rb3 cdiamond-3 intel calpella-platform-with uma gfx 981211 1
This Quanta LD-Note Calpella UMA motherboard is built on the Intel Calpella platform with UMA graphics, featuring an Arrandale processor in an rPGA 989 socket paired with the Ibex Peak-M Intel 5 Series Express Chipset. The system uses dual-channel DDR3 SODIMM memory running at 800/1067 MHz and 1.5V. The embedded controller is an ITE8502, and the audio subsystem is handled by a Realtek ALC269Q codec. Power management is provided by a combination of ISL6237IRZ-T, ISL62882, MAX17028, TPS51116REGR, and RT8204 regulators, with an ISL88731 charger IC supporting battery discharge. Networking is handled by a Realtek RTL8111DL LAN controller, and the board includes a PS8101 HDMI level shifter, an R5538 USB hub IC, and an SLG8SP585V clock generator. The board also features a discrete TPM, a G990P11U accelerometer, and a PI3L500-AZFEX LAN switch.
Q: What BIOS flash configuration is used on this motherboard?
A: The schematic references two SPI flash devices: a 2Mbyte flash and a 4Mbyte flash.
A: The embedded controller is an ITE8502.
A: The charging IC is an ISL88731, and the architecture supports battery discharge.
| Project Code | LD-Note Calpella UMA |
| Date | Friday, December 11, 2009 |
| CPU Platform | Intel Calpella Platform with UMA GFX |
| CPU Model | Arrandale |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | Ibex Peak-M (Intel(R) 5 Series Express Chipset) |
| GPU Type | UMA |
| EC / KBC | ITE8502 |
| EC/KBC Package | EHOLD & SKEW |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | FLASH 2Mbyts, FLASH 4Mbyts |
| Charging IC | ISL88731 |
| Charger Architecture | Discharge |
| Power IC(s) | ISL6237IRZ-T, ISL62882, MAX17028, TPS51116REGR, RT8204 |
| RAM Architecture | Dual Channel DDR3 800/1067 1.5V |
| RAM Quantity / Slots | DDR3 - SODIMM0, DDR3 - SODIMM1 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | MINI-CARD WLAN/WiMAX |
| HDMI Level Shifter | PS8101 |
| Card Reader IC | Card Reader /Finger Print/RF CONN. |
| USB Hub IC | R5538 |
| Clock Generator | SLG8SP585V(QFN32) |
| LAN Switch | PI3L500-AZFEX |
| LAN Switch (Dock) | SN74CBT3257CPWR |
| Accelerometer | G990P11U |
| TPM | Discrete TPM |
Calpella
Arrandale
989
UMA
IT8502
ALC269Q
ISL88731
ISL6237IRZ-T
ISL62882
MAX17028
RT8204
TPS51116REGR
RTL8111DL
PS8101
R5538
SLG8SP585V
PI3L500-AZFEX
G990P11U
Motion / Position Sensor
Calpella
Arrandale
989
UMA
IT8502
ALC269Q
ISL88731
ISL6237IRZ-T
ISL62882
MAX17028
RT8204
TPS51116REGR
RTL8111DL
PS8101
R5538
SLG8SP585V
PI3L500-AZFEX
G990P11U
