samsung np-r410 ba41-00529a ba92-03859a aquil-so rev 1.0
The Samsung X06 motherboard, project code Aquila-Sonoma, board number BA41-00529A revision 1.0, is built on the Intel Alviso + ICH6-M platform supporting Dothan and Yonah processors. Graphics are handled by the Alviso-GM internal graphics controller. The system firmware is stored in an 82802AC FWH flash IC. Audio is managed by an AD1981B AC’97 codec. The board uses a MICOM EC/KBC controller. Memory architecture consists of dual-channel DDR II across two SODIMM slots. Networking is provided by a BCM5788 LAN controller and a separate Wireless LAN module. The R5C841 IC handles both CardBus and charging functions. Clock generation is managed by the CK-410 clock generator, and thermal monitoring is performed by the EMC6N300 sensor.
Q: What BIOS flash IC is used on this motherboard?
A: The motherboard uses an 82802AC FWH flash IC.
A: The board uses a MICOM EC/KBC controller.
A: The motherboard supports dual-channel DDR II memory across two SODIMM slots.
A: The audio codec is an AD1981B AC’97 codec.
| Brand | Samsung |
| Model | X06 |
| Motherboard Manufacturer | Samsung Electronics |
| Project Code | Aquila-Sonoma |
| Board Number | BA41-00529A |
| Date | June 25, 2005 |
| CPU Platform | Intel Alviso + ICH6-M |
| CPU Model | Dothan (w/533MHz) & Yonah |
| PCH / Southbridge | ICH6-M |
| GPU Type | Internal Graphics |
| Graphics Architecture | Alviso-GM |
| EC / KBC | MICOM |
| Audio Codec | AD1981B |
| BIOS / SPI Flash | FWH |
| BIOS Flash Exact Model | 82802AC |
| Charging IC | R5C841 |
| RAM Type | DDR II |
| RAM Architecture | Dual channel |
| LAN IC | BCM5788 |
| WiFi / WLAN IC | Wireless LAN |
| Card Reader IC | R5C841 |
| USB Hub IC | CK-410 |
| Thermal Sensor | EMC6N300 |
BA41-00529A
Alviso
533MHz)
ICH6
Internal Graphics
Alviso-GM
AD1981B
82802AC
R5C841
BCM5788
R5C841
CK-410
EMC6N300
BA41-00529A
Alviso
533MHz)
ICH6
Internal Graphics
Alviso-GM
AD1981B
82802AC
R5C841
BCM5788
R5C841
CK-410
EMC6N300
