samsung np r20 ba41-00809a gce ba41-00810a nanya
The Samsung HAINAN2 motherboard, board number BA41-XXXXXA revision 1.0, is built around the Intel Merom CPU platform with an RS600M and SB600 chipset. The system uses a Hitachi H8S-2110B EC/KBC and stores its BIOS on an MX25L8005 SPI flash IC. Audio is handled by an ALC262 codec, while networking is provided by an RTL8100CL LAN IC. Power management includes a MAX1909ETI+T charging IC and multiple power ICs such as MAX8734AEEI+T, MAX8734B, MAX8632ETI+T, and ISL6227CAZ-T. Memory configuration consists of two DDR II SODIMM slots operating in single-channel architecture. The RS600M provides internal graphics, and a clock generator ICS95461 is used. An AU6366 card reader IC is also present.
Q: What BIOS IC model is used on this Samsung HAINAN2 motherboard?
A: The BIOS is stored on an MX25L8005 SPI flash IC.
Q: What EC/KBC chip is used on this motherboard?
A: The EC/KBC is a Hitachi H8S-2110B.
A: The charging IC is a MAX1909ETI+T.
Q: What is the memory configuration of this motherboard?
A: The motherboard uses two DDR II SODIMM slots in a single-channel architecture.
| Brand | Samsung |
| Model Name | HAINAN2 |
| Project Code | HAINAN2 |
| Board Number | BA41-XXXXXA |
| Date | November 2, 2006 |
| CPU Platform | Intel Merom |
| Chip Set | RS600M & SB600 |
| EC / KBC | Hitachi H8S-2110B |
| Audio Codec | ALC262 |
| BIOS / SPI Flash | MX25L8005 |
| LAN IC | RTL8100CL |
| Charging IC | MAX1909ETI+T |
| Power IC(s) | MAX8734AEEI+T, MAX8734B, MAX8632ETI+T, ISL6227CAZ-T, MIC5219BM5, SC4521, SI4435DY, FDS6680A, SS338A1, SS338A4 |
| RAM Type | DDR II |
| RAM Architecture | Single channel |
| Card Reader IC | AU6366 |
| Clock Generator | ICS95461 |
| GPU Type | Internal Graphics ([URL="https://dr-bios.com/components/graphics-models/rs600m/"]RS600M)[/URL] |
HAINAN2
Merom
HITACHI H8S/2110B
ALC262
MX25L8005
RTL8100CL
MAX1909ETI+T
FDS6680A
ISL6227CAZ-T
MAX8632ETI
MAX8734AEEI
MAX8734B
MIC5219BM5
SC4521
SI4435DY
SS338A1
SS338A4
AU6366
ICS95461
Internal Graphics
RS600M
HAINAN2
Merom
HITACHI H8S/2110B
ALC262
MX25L8005
RTL8100CL
MAX1909ETI+T
FDS6680A
ISL6227CAZ-T
MAX8632ETI
MAX8734AEEI
MAX8734B
MIC5219BM5
SC4521
SI4435DY
SS338A1
SS338A4
AU6366
ICS95461
Internal Graphics
RS600M
