quanta quanta ql4 n10p sw s3 1009 1
The Quanta QL4NB5 project is a notebook motherboard platform dated October 2009, supporting both Auburndale 35W and Clarksfield 45W CPU platforms with an Ibex-M PCH. Graphics options include N10P-GE and N10M-GE discrete GPUs with 128-bit memory interface, alongside UMA configuration support. The system uses DDR III memory via two DDRIII-SODIMM slots supporting 800/1066 MT/s. The embedded controller is a KB3926 C0, and the audio codec is an ALC272. Power management is handled by a suite of ICs including the ISL6251AHAZ-T system charger, ISL6288 CPU core regulator, RT8208A, RT8204, RT8206B, and RT8152A. Networking is provided by an AR8131(M) GagaLAN Atheros PCIE-LAN controller. The board features an RTS5159 for both HDMI level shifting and card reader functions, and a TPA6017A2 audio amplifier. The clock generator is an RTM875N-632-GR, and the system utilizes SPI flash for BIOS storage.
A: The embedded controller is a KB3926 C0.
A: Yes, the block diagram explicitly indicates both Discrete and UMA configuration support.
A: The system charger is an ISL6251AHAZ-T, with the architecture labeled as SYSTEM CHARGER.
A: It supports DDR III memory at 800/1066 MT/s via two DDRIII-SODIMM slots.
| Project Code | QL4NB5 |
| Date | Friday, October 09, 2009 |
| CPU Platform | Auburndale 35W / Clarksfield 45W |
| PCH / Southbridge | Ibex-M |
| GPU Type | N10P-GE / N10M-GE |
| Graphics Architecture | 128 Bit |
| EC / KBC | KB3926 C0 |
| Audio Codec | ALC272 |
| BIOS / SPI Flash | SPI |
| Charging IC | ISL6251AHAZ-T |
| Charger Architecture | SYSTEM CHARGER |
| Power IC(s) | RT8208A / RT8204 / RT8206B / RT8152A / ISL6288 |
| RAM Type | DDR III |
| RAM Architecture | DDRIII-SODIMM x2 |
| LAN IC | AR8131(M) GagaLAN |
| WiFi / WLAN IC | Atheros PCIE-LAN |
| HDMI Level Shifter | RTS5159 |
| Card Reader IC | RTS5159 |
| USB Hub IC | LRS3197 |
| Audio Amplifier | TPA6017A2 |
| Clock Generator | RTM875N-632-GR |
| dGPU to UMA Conversion Support | Dis. & UMA |
QL4NB5
Auburndale
Clarksfield
N10M-GE
N10P-GE
128 Bit
KB3926 C0
ALC272
ISL6251AHAZ-T
ISL6288
RT8152A
RT8204
RT8206B
RT8208A
AR8131 GAGALAN
RTS5159
LRS3197
TPA6017A2
RTM875N-632-GR
QL4NB5
Auburndale
Clarksfield
N10M-GE
N10P-GE
128 Bit
KB3926 C0
ALC272
ISL6251AHAZ-T
ISL6288
RT8152A
RT8204
RT8206B
RT8208A
AR8131 GAGALAN
RTS5159
LRS3197
TPA6017A2
RTM875N-632-GR
