MSI MS-9632 Rev 10 1.3 10b 10a 0a Schematic
The MSI MS-9631 motherboard, revision 0A, is built around the Intel 945GT GMCH north bridge and ICH7M-DH south bridge, supporting Intel Yonah or Merom processors. System memory consists of two DDR2 DIMM slots with a maximum capacity of 4GB. The board utilizes an FWH EEPROM for BIOS storage and features the W83627EHF Super I/O and EC/KBC controller. Audio is handled by the Azalia ALC880 codec, while networking is provided by dual Intel 82573E LAN controllers. The VIA VT6307 controller manages IEEE 1394 connectivity, and the SIL 3132 controller provides SATA II support. A CH7307 level shifter enables DVI output, and the ISL6262 IMVP-6 controller manages CPU core voltage. The ICS954129 clock generator provides system timing, and an Infineon SLD9635 TPM module is included for security.
Q: What type of BIOS flash is used on this motherboard?
A: The MS-9631 uses an FWH (Firmware Hub) EEPROM for BIOS storage, connected via the LPC bus.
A: The W83627EHF Super I/O controller serves as the EC/KBC on this board.
Q: What is the charging/power controller for the CPU?
A: The ISL6262 IMVP-6 controller manages the CPU core voltage regulation.
A: The Azalia ALC880 codec provides audio functionality.
The MSI MS-9632 revision 1.3 motherboard, dated April 19, 2007, is built around the Intel Yonah/Merom processor platform with an Intel 945 GT GMCH north bridge and Intel ICH7R south bridge. System memory consists of two DDR2 slots supporting up to 4GB. The board utilizes a Winbond W83627EHF Super I/O for LPC and EC/KBC functions. Audio is provided by an Azalia ALC880/883/888 codec. Networking is handled by an Intel 82573E LAN controller. The BIOS is stored on a FWH EEPROM with SPI interface support. Power management is controlled by an ISL6262 IMVP-6 controller. The board includes a VIA VT6307 IEEE1394 controller, a CH7307 HDMI level shifter, and a SIL 3132 SATA2 controller. Clock generation is managed by an ICS954129 clock generator. A TPM module from Infineon (SLD9635) is also present.
Q: What BIOS flash technology is used on this motherboard?
A: The MS-9632 uses a FWH EEPROM with SPI (Serial Peripheral Interface) support for the BIOS flash device.
A: The board uses a Winbond W83627EHF Super I/O controller for LPC and EC/KBC functions.
Q: What is the power management controller on this board?
A: The board uses an ISL6262 IMVP-6 controller for CPU V-core PWM regulation.
A: The board supports Azalia ALC880, ALC883, or ALC888 audio codecs.
The MSI MS-9631 (Revision 0A) motherboard is built around the Intel Yonah/Merom processor platform with the Intel 945GT GMCH (North Bridge) and Intel ICH7M-DH (South Bridge). System memory is supported via two DDR2 DIMM slots with a maximum capacity of 4GB. The board utilizes an FWH EEPROM for BIOS storage and features the W83627EHF Super I/O and EC/KBC controller. Audio is handled by the Azalia ALC880 codec, while networking is provided by the Intel 82573E LAN controller. The VIA VT6307 IEEE 1394 controller and SIL 3132 SATA II controller expand connectivity options. Power management is governed by the ISL6262 IMVP-6 controller, and clock generation is managed by the ICS954129. The board also includes an Infineon SLD9635 TPM module and a CH7307 DVI transmitter.
Q: What BIOS type is used on the MSI MS-9631?
A: The board uses an FWH EEPROM for BIOS storage.
A: The W83627EHF Super I/O serves as the EC/KBC controller.
Q: What is the CPU platform and chipset configuration?
A: The board supports Intel Yonah/Merom processors with the Intel 945GT GMCH (North Bridge) and Intel ICH7M-DH (South Bridge).
Q: What memory configuration does the MS-9631 support?
A: It supports DDR2 memory via two DIMM slots with a maximum capacity of 4GB.
The MSI MS-9631 motherboard, revision 0A, is built around the Intel Yonah/Merom processor platform using a Yonah 478-pin socket. The system chipset consists of the Intel 945 GT GMCH (North Bridge) paired with the Intel ICH7M-DH (South Bridge). Memory architecture supports up to 4GB of DDR2 across two modules. The onboard EC/KBC is a Winbond W83627EHF LPC Super I/O controller. Audio is handled by an Azalia ALC880 codec. The BIOS is stored on a Firmware Hub (FWH) EEPROM. Power management uses an ISL6262 IMVP-6 controller for V-core PWM. Networking is provided by an Intel 82573E LAN controller. The board includes a VIA-6307 IEEE1394 controller for FireWire connectivity.
A: The board number is MS-9631, revision 0A.
A: The EC/KBC is a Winbond W83627EHF LPC Super I/O controller.
Q: What type of BIOS storage is used on this motherboard?
A: The BIOS is stored on a Firmware Hub (FWH) EEPROM.
Q: What is the CPU platform and socket type?
A: The CPU platform is Intel Yonah/Merom, using a Yonah 478-pin socket.
Q: What charging and power IC is used for V-core regulation?
A: The V-core PWM controller is an ISL6262 IMVP-6 controller.
| Brand | MSI (Micro-Star International) |
| Model | MS-9631 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO., LTD. |
| Board Number | MS-9631 |
| Revision | 0A |
| Date | Friday, December 09, 2005 |
| CPU Platform | Intel Yonah/Merom Processor |
| PCH / Southbridge | Intel ICH7M-DH |
| GPU Type | [URL="https://dr-bios.com/components/graphics-models/945gt/"]Intel 945GT[/URL] - GMCH (North Bridge) |
| EC / KBC | W83627EHF |
| Audio Codec | Azalia ALC880 |
| BIOS / SPI Flash | FWH EEPROM |
| Charging IC | ISL6262 |
| RAM Type | DDR2 |
| LAN IC | Intel 82573E |
| Card Reader IC | VIA VT6307 |
| USB Hub IC | SIL 3132 |
| WiFi / WLAN IC | Intel 82573E |
| HDMI Level Shifter | CH7307 |
| TPM | Infineon SLD9635 |
| Clock Generator | ICS954129 |
| Super I/O | W83627EHF |
| Power Controller | ISL6262 |
| SATA Controller | SIL 3132 |
| IEEE 1394 Controller | VIA VT6307 |
| Model | MS-9632 |
| Motherboard Manufacturer | MICRO-STAR INt'L CO., LTD. |
| Board Number | ms-9632-1-3/"]MS-9632 1.3[/URL] |
| Revision | 1.3 |
| Date | Thursday, April 19, 2007 |
| CPU Socket | Intel Yonah Processor/Intel Merom Processor |
| PCH / Southbridge | Intel ICH7R (South Bridge) |
| GPU Type | Intel 945 GT - GMCH (North Bridge) |
| Graphics Architecture | Intel 945GT |
| EC / KBC | Winbond W83627EHF |
| Audio Codec | Azalia ALC880 / ALC883 / ALC888 |
| BIOS / SPI Flash | FWH EEPROM / SPI |
| Charging IC | ISL 6262 |
| Power IC(s) | isl6262/"]IMVP-6 Controller: ISL6262[/URL] |
| RAM Type | DDR2 |
| RAM Architecture | DDR2 System Memory 1 & 2 |
| RAM Quantity / Slots | DDR 2 * 2 (Max 4GB) |
| Card Reader IC | [URL="https://dr-bios.com/components/card-reader-ic/vt6307/"]VIA VT6307 IEEE1394 Controller[/URL] |
| USB Hub IC | VIA-6307 IEEE1394 Controller |
| Thermal Sensor | Infineon SLD9635 TPM |
| SATA Controller | [URL="https://dr-bios.com/components/storage-controller/sil3132/"]SIL 3132 SATA2 Controller[/URL] |
| Model | MS-9631 |
| Revision | 0A |
| Date | Wednesday, February 22, 2006 |
| RAM Type | DDR 2 |
| RAM Quantity / Slots | 2 (Max 4GB) |
| DVI Transmitter | CH7307 |
| Model | MS-9631 |
| Motherboard Manufacturer | MICRO-STAR INt'L CO. , LTD. |
| Revision | 0A |
| Date | Thursday, April 20, 2006 |
| CPU Socket | Yonah 478pin socket (keyed) |
| Power IC(s) | ISL6262 |
| RAM Type | DDR2 |
| RAM Architecture | 2 DDR II Modules |
| Card Reader IC | VIA-6307 IEEE1394 Controller |
| Model | MS-9632 |
| Board Number | ms-9632-1-0-ms-9632-1-0a-ms-9632-1b/"]MS-9632 1.0 / MS-9632 1.0A / MS-9632 1B[/URL] |
| Revision | 1B |
| Date | Tuesday, March 20, 2007 |
| Document Number | 11AAMS-96322007.03.08 |
| CPU Socket | Intel Yonah CPU |
| PCH / Southbridge |
