MSI MS-95M8 Rev 0A 1.0 Schematic
This Micro-Star International motherboard, designated MS-95M8-0A, is designed for the 9192 MainBoard platform. The board carries the document number MS-95M80 and is revision A, dated Friday, April 27, 2007. The schematic details a golden finger interface configuration supporting PCI Express and PCI slots, with strap resistor options (R1X_0, R58X_5.6K, R63X_5.6K, R60, R59X_5.6K, R615.6K, R20) to select between one PCIe x8, two PCIe x4, or various PCI slot counts based on GPI pin strapping. The interface includes PCI Express lanes (PCIE1_RX/TX) and PCI-X signals, with specific routing for clock, reset, and power management signals.
A: The board number is MS-95M80, revision A.
Q: What is the document date for this schematic?
A: The schematic is dated Friday, April 27, 2007.
Q: How is the PCIe/PCI slot configuration selected on this board?
A: The configuration is selected via GPI pin strapping (GPI0, GPI1, GPI2) and associated strap resistors (R1X_0, R58X_5.6K, R63X_5.6K, R60, R59X_5.6K, R615.6K, R20) to enable one PCIe x8, two PCIe x4, or one/two/three PCI slots.
This Micro-Star International motherboard, identified as the MS-95M8-0A for the 9192 MainBoard, is a custom platform designed with a flexible PCI Express and PCI slot configuration. The board revision is B, with a document date of Wednesday, August 22, 2007. The schematic details a golden finger interface supporting configurable slot counts, including options for one PCIe x8, two PCIe x4, and up to three PCI slots, controlled by GPIO strapping resistors. The board utilizes a PCIX1 and PCIE2-X4, PCIE3-X4 slot arrangement, with the PCI Express interface routed through a switch IC (U1) and associated pull-up resistors for lane configuration.
Q: What is the board number and revision for this motherboard?
A: The board number is MS-95M8-0A, revision B, dated Wednesday, August 22, 2007.
Q: What PCI Express slot configurations are supported on this board?
A: The board supports configurable slot configurations including one PCIe x8, two PCIe x4, and up to three PCI slots, controlled by GPIO strapping on the golden finger interface.
| Brand | Micro-Star Int'l Co., Ltd. |
| Model | MS-95M8-0A (for 9192 MainBoard) |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Board Number | MS-95M80 |
| Revision | A |
| Date | Friday, April 27, 2007 |
| Document Number | MS-95M80 |
| Board Number | MS-95M8-0A |
| Revision | B |
| Date | Wednesday, August 22, 2007 |
| Document Number | MS-95M8 |
| CPU Platform | Custom |
