MSI MS-95M7 Rev 0A 10 Schematic
This Micro-Star MS-95M7 motherboard, documented under schematic number AMS-95M7 revision 0A dated March 5, 2007, is a server-class board designed for 2U chassis integration. The board features multiple SAS and SATA storage interfaces, including SAS1, SAS2, SATA1, and SATA2 connectors, alongside a SAS controller at U3000. Connectivity is provided through COM1, USB1, and JUSB3001 headers, with extensive fan headers (FAN1-FAN4, FAN2001-FAN2004) for thermal management in dense server environments. The layout includes standard power connectors JPWR1 and JPWR2, IDE1, and floppy connector JCFD1, with front panel I/O at JFP1 and JIO1.
Q: What is the board number and revision for this Micro-Star motherboard?
A: The board is the MS-95M7, revision 0A, with document number AMS-95M7.
Q: What storage interfaces are present on this motherboard?
A: The board includes SAS1, SAS2, SATA1, SATA2 connectors and a SAS controller at U3000, plus IDE1.
This MICRO-STAR motherboard is identified by board number MS-95M7, revision 1.0, with a document number of MS-95M715. The schematic was dated Tuesday, August 07, 2007. The board layout includes connections for 2U boards, SAS controllers, SATA ports, USB headers, fan headers, power connectors, and IDE interfaces. Key components referenced include U3000, JMB1, and various SAS and SASC connectors, indicating a server-oriented platform design.
A: The board number is MS-95M7, revision 1.0.
A: The document number is MS-95M715.
Q: What date is listed on the schematic cover?
A: The schematic cover is dated Tuesday, August 07, 2007.
| Brand | MICRO-STAR |
| Model | MS-95M7 |
| Document Number | AMS-95M7 |
| Revision | 0A |
| Date | 2007/03/05 |
| Board Number | MS-95M7 |
| Date | Tuesday, August 07, 2007 |
| Document Number | MS-95M715 |
