Schematic MSI MS-95M5 Rev 0A 10 Schematic
BrandMICRO-STAR
ModelMS-95M5
Motherboard ManufacturerMICRO-STAR
Board NumberMS-95M5
Revision0A
Date2007/03/02
Document NumberAMS-95M5
CPU PlatformI39
PCH / SouthbridgeSB6
EC / KBCepm570t100c5n/"]U2 EPM570T100C5N[/URL]
EC/KBC PackageTQFP100
EC/KBC ProgrammableYes (CPLD, JTAG references present)
Charging ICU3000
RAM TypeDDR2
RAM ArchitectureDual Channel
RAM Quantity / Slots4
LAN ICJMB1
WiFi / WLAN ICJMB1
Card Reader ICJMB1
USB Hub ICJMB1
Audio CodecALC888
BIOS / SPI FlashSST 49LF004B
BIOS Flash Exact ModelSST 49LF004B
BIOS Flash ManufacturerSST
BIOS Flash Capacity4 Mbit
BIOS Flash PackagePLCC-32
Compatible BIOS IC ModelsSST 49LF004B
EC Flash / ROMEPM570T100C5N (internal flash)
Power IC(s)U3000
Thermal SensorADM1032
GPU TypeIntegrated
Graphics ArchitectureIntel GMA 950
dGPU Chip NumberN/A (integrated only)
dGPU to UMA Conversion SupportNo (integrated only)
The MICRO-STAR MS-95M5 Rev 0A is a server motherboard based on the Intel I39 platform with an SB6 southbridge. It utilizes an SST 49LF004B PLCC-32 BIOS flash for system firmware. The embedded controller is an Altera EPM570T100C5N CPLD in a TQFP100 package, which is programmable via JTAG. The board supports DDR2 memory in a dual-channel configuration across four slots. Integrated graphics is provided by the Intel GMA 950 architecture. The system includes a JMB1 controller for LAN, WiFi, card reader, and USB hub functions. Audio is handled by the ALC888 codec. Power management is managed by the U3000 charging IC, and thermal monitoring is provided by the ADM1032 sensor. The board is documented under document number AMS-95M5 with a date of 2007/03/02.
A: The BIOS flash is an SST 49LF004B in a PLCC-32 package with 4 Mbit capacity.
A: Yes, the EC is an Altera EPM570T100C5N CPLD in a TQFP100 package, which is programmable via JTAG.
Q: What is the memory architecture of this motherboard?[/
BrandMSI (Micro-Star)
ModelMS-95M5
Motherboard ManufacturerMSI (Micro-Star)
Board NumberMS-95M5
Revision1.0
DateTuesday, August 07, 2007
Document NumberMS-95M5
EC / KBCEPM570T100C5N
This MSI MS-95M5 server motherboard, documented on August 7, 2007, is built around a CPLD-based management architecture. The primary programmable device is an Altera EPM570T100C5N CPLD in a TQFP100 package, which handles system management, LED control, and SAS/SATA backplane signaling. The board includes a 32.768 kHz oscillator for real-time clock functions and features multiple SAS and SATA connectors, fan headers, and a dedicated DSD (Drive Status Display) interface. The schematic indicates a 2U form factor with extensive backplane connectivity, including SGPIO and I2C-like management buses for drive enclosure monitoring. The board supports RAID configuration via a RAID_SEL jumper and includes JTAG programming access for the CPLD.
Q: What is the main programmable controller on this motherboard?
A: The main programmable controller is an Altera EPM570T100C5N CPLD in a TQFP100 package.
Q: Is the CPLD programmable on this board?
A: Yes, the EPM570T100C5N CPLD has JTAG signals (TMS, TCK, TDI, TDO) present for programming and debugging.
A: The board number is MS-95M5, revision 1.0, dated August 7, 2007.
  • MSI MS-95M5 Rev 0A_20070418 Schematic.pdf
  • MSI MS-95M5 Rev 10_20070807 Schematic.pdf
