Schematic MSI MS-95L9 Rev 0A 0B Schematic
BrandMSI
ModelMS-95L9-0A
Board NumberMS-95L9-0A
Revision0A
DateTuesday, July 04, 2006
Document NumberL9 / PCIEx8 to PCIX 64 Riser
CPU PlatformDual CPU (CPU1, CPU2)
Platform Alias9182 MainBoard
RAM ArchitectureMemory x 8 (two banks)
RAM Quantity / SlotsMemory x 8
This MSI MS-95L9-0A riser card, revision 0A, dated July 4, 2006, is designed as a PCI Express x8 to PCI-X 64-bit bridge for the 9182 MainBoard platform. The board supports a dual CPU configuration with CPU1 and CPU2, and features two banks of Memory x 8 architecture. It provides PCI Express x16 and x8 slots, along with SAS1 and SAS2 controllers. The riser includes a PCI-X 133MHz slot and a PCI Express Gold Finger connector, utilizing a PXH PCI-X Bridge for Bus A at 133MHz. The document is identified as L9 / PCIEx8 to PCIX 64 Riser.
Q: What is the board number and revision of this riser card?
A: The board number is MS-95L9-0A, revision 0A.
Q: What CPU configuration does this riser support?
A: This riser supports a dual CPU configuration with CPU1 and CPU2.
Q: What memory architecture is used on this board?
A: The board features Memory x 8 architecture across two banks.
Q: What is the main bridge controller used on this riser?
A: The riser uses a PXH PCI-X Bridge for Bus A at 133MHz.
Document NumberMS-95J5-0A
RevisionB1
DateThursday, February 01, 2007
CPU PlatformL9 / PCIEx8 to PCIX 64 Riser
This document covers the MS-95L9-0A riser board, identified under document number MS-95J5-0A, revision B1, dated Thursday, February 01, 2007. The board is designed as an L9 / PCIEx8 to PCIX 64 Riser, intended for use with the 9182 MainBoard. The platform architecture includes PCI Express x16 and x8 slots, PCIX 133MHz slots, and SAS controllers, supporting dual CPU configurations and eight memory modules.
Q: What is the document number and board number for this riser?
A: The document number is MS-95J5-0A, and the board number is MS-95L9-0A.
Q: What is the revision of this riser board?
A: The revision is B1.
Q: What is the platform architecture of this riser?
A: The platform is an L9 / PCIEx8 to PCIX 64 Riser, supporting PCI Express x16 and x8 slots, PCIX 133MHz slots, and SAS controllers.
  • MSI MS-95L9 Rev 0A Schematic.pdf
  • MSI MS-95L9 Rev 0B Schematic.pdf
