Schematic MSI MS-95L7 Rev 1.1 0b Schematic
BrandAMS
Model95L7
Motherboard ManufacturerAMS
Board Number95L7
DateWednesday, May 10, 2006
Document NumberEXP_A
RevisionCustom11
TitlePCIEx8 Golden Finger
This AMS 95L7 document, dated Wednesday, May 10, 2006, is a custom revision 11 schematic for a PCIEx8 Golden Finger riser card. The board number is 95L7, and the document number is EXP_A. The schematic details a PCI Express x8 riser card design, featuring two PCI-E 8PORT connectors (BS2 and BS1) and associated power delivery components including 12V and 3.3V rails. The design includes decoupling capacitors such as C1 (0.1u 16V C3K X7R), C5 (100u 6.3V POS), and C2 (100u 6.3V POS). The riser card provides standard PCIe signals including reference clocks (PCIE_100CLK_P/N), reset (PCIE_RSTJ), and wake (WAKE_N), along with SMBus lines (SCL2, SDA2) and JTAG interface signals.
Q: What is the board number and revision of this riser card?
A: The board number is 95L7, and the revision is Custom11.
A: The document number is EXP_A.
Q: What type of PCIe interface does this riser card support?
A: This riser card supports a PCI Express x8 (PCIEx8) Golden Finger interface.
BrandCustom
ModelAMS-95L7 / PCIEx8 riser
Board NumberX_P-95F2
Document Number0
This document covers the Custom AMS-95L7 / PCIEx8 riser board, identified by board number X_P-95F2. The schematic is dated Wednesday, May 10, 2006, with document number 0. The board is a PCIe x8 Golden Finger riser card, featuring two PCI-E 8-port connectors (PCIE1 and PCIE2) and associated passive components including capacitors C5, C6, C14, C2, C3, C1, C7, C8, C9, C10, C11, and C12. Power rails present on the board include P3V3, P3V3_DUAL, and P12V. The design includes test points FM1, FM2, and FM13X_PANEL_PAD, as well as ferrite beads BS1 and BS2.
Q: What is the board number for this riser card?
A: The board number is X_P-95F2.
Q: What is the document number and date of this schematic?
A: The document number is 0, and the date is Wednesday, May 10, 2006.
Q: What type of connectors are used on this riser board?
A: The board uses two PCI-E 8-port connectors, labeled PCIE1 and PCIE2, configured as a PCIe x8 Golden Finger interface.
  • MSI MS-95L7 Rev 0A 0510 Schematic.pdf
  • MSI MS-95L7 Rev 1.1 Schematic.pdf
