MSI MS-9575 Rev 0A 10A Schematic
This Dell PE2800C1325 X03 daughter board, part of the Corvette 1x2/Kobuk project, is built around the QLogic GEM359 CPU platform. The board utilizes a 512Kx8 Flash ROM for BIOS/SPI storage and features a FRU microcontroller interface with JTAG programming capability for the EC/KBC. The architecture includes SCSI LVD termination, I2C0 and I2C1 ports, an IPMB private I2C bus, and CPLD logic control. The board supports drive presence detection and drive power management, with debug ports and SMVU port for diagnostics. Multiple build
This Dell Inc. Corvette 1x2/Kobuk Daughter Board, schematic number C1325 and board number C1324, revision A01, dated 1/24/06, is built around the QLOGIC GEM359 microcontroller. The GEM359 serves as the primary EC/KBC, with JTAG interface for programming and debugging. The board utilizes a FLASH ROM 512KX8 for BIOS/SPI storage. The design includes CPLD logic, SCSI LVD termination, and I2C bus interfaces. The board supports multiple build configurations including prototype and production builds, with PWB color options of Green with White Silkscreen.
Q: What is the EC/KBC microcontroller used on this board?
A: The QLOGIC GEM359 microcontroller is used as the primary EC/KBC.
Q: Is the EC/KBC programmable on this board?
A: Yes, the QLOGIC GEM359 supports programming via JTAG interface.
Q: What type of BIOS/SPI flash memory is used?
A: The board uses a FLASH ROM 512KX8 for BIOS/SPI storage.
Q: What are the board and schematic numbers for this Dell daughter board?
A: The board number is C1324 and the schematic number is C1325, revision A01.
This Dell Computer Corporation daughter board, designated as board number 1325A00 revision X04, is a Corvette 1x2/Kobuk design dated March 25, 2004. The platform is built around the QLogic GEM359 controller, which also serves as the LAN IC. The system utilizes a FRUMicrocontroller for EC/KBC functions and features a FLASHROM 512KX8 for BIOS/SPI flash storage, interfacing via an address and data bus architecture. The board includes SCSI LVD termination for its charger architecture and incorporates CPLD logic, JTAG interface, and I2C bus management. The schematic is configured for use with the XLBOM utility and supports SCSI ID, debug ports, and IPMB bus communication.
Q: What is the board number and revision of this Dell daughter board?
A: The board number is 1325A00, revision X04.
Q: What controller is used as the CPU platform and LAN IC?
A: The QLogic GEM359 serves as both the CPU platform and the LAN IC.
Q: What type of BIOS flash memory is used?
A: The board uses a FLASHROM 512KX8.
Q: What microcontroller is used for EC/KBC functions?
A: The board uses a FRUMicrocontroller.
| Brand | DELL COMPUTER CORPORATION |
| Model | PE2800C1325 |
| Board Number | X03 |
| Date | 12/19/03 |
| Drawing Number | ABC1234 |
| Revision | X03 |
| CPU Platform | GEM359 |
| EC / KBC | FRUMICROCONTROLLER |
| BIOS / SPI Flash | FLASHROM 512KX8 |
| Charger Architecture | SCSI LVD TERMINATION |
| LAN IC | QLOGIC GEM359 |
| RAM Type | DRIVE POWER |
| RAM Architecture | ADDRESS BUS DATA BUS |
| RAM Quantity / Slots | DRIVE PRESENCE |
| Card Reader IC | SCSI ID |
| USB Hub IC | I2C0 PORT I2C1 PORT |
| WiFi / WLAN IC | IPMB BUS PRIVATE I2C BUS |
| HDMI Level Shifter | DEBUG PORTS |
| Power IC(s) | CPLD LOGIC CONTROL |
| Thermal Sensor | SMVUPORT |
| Audio Codec | SPARES |
| GPU Type | SCSI BUS TERMINATION |
| Graphics Architecture | DAUGHTER BLOCK DIAGRAM |
| dGPU Chip Number | BKPLN/DTR MATING CONNECTOR |
| dGPU to UMA Conversion Support | BUILD0 IS 5U 1X2 DC PROTOTYPE BUILD |
| EC/KBC Package | JTAG |
| EC/KBC Programmable | JTAG |
| BIOS Flash Exact Model | FLASHROM 512KX8 |
| BIOS Flash Manufacturer | FLASHROM |
| BIOS Flash Capacity | 512KX8 |
| BIOS Flash Package | FLASHROM |
| Compatible BIOS IC Models | FLASHROM 512KX8 |
| EC Flash / ROM | FRUMICROCONTROLLER INTERFACE |
| Charging IC | SCSI LVD TERMINATION |
| Project Code | CORVETTE 1x2/KOBUK DAUGHTER BOARD |
| Motherboard Manufacturer | DELL COMPUTER CORPORATION |
| Platform Alias | PE2800C1325 |
| CPU Model | GEM359 |
| CPU Socket | GEM359 |
| PCH / Southbridge | QLOGIC GEM359 |
| Brand | Dell Inc. |
| Motherboard Manufacturer | Dell Inc. |
| Board Number | C1324 |
| Schematic Number | C1325 |
| Revision | A01 |
| Date | 1/24/06 |
| EC / KBC | QLOGIC GEM359 |
| BIOS / SPI Flash | FLASH ROM 512KX8 |
| Board Number | 1325A00 |
| Revision | X04 |
| Date | 3/25/04 |
| CPU Platform | gem359/"]QLOGIC GEM359[/URL] |
| RAM Type | 512KX8 |
X03
GEM359
FLASHROM 512KX8
QLOGIC GEM359
DRIVE POWER
I2C0 PORT I2C1 PORT
1X2
PE2800C1325
GEM359
QLOGIC GEM359
C1324
QLOGIC GEM359
1325A00
Qlogic GEM359
512KX8
X03
GEM359
FLASHROM 512KX8
QLOGIC GEM359
DRIVE POWER
I2C0 PORT I2C1 PORT
1X2
PE2800C1325
GEM359
QLOGIC GEM359
C1324
QLOGIC GEM359
1325A00
Qlogic GEM359
512KX8
