MSI MS-95D6 Rev 2.0 10a a01 a02 Schematic
[TD]
[TD]
This motherboard schematic, dated Wednesday, July 06, 2005, includes NV-SLI Connector sections with detailed PCI Express lane routing for X16, X8, X4, and X4 configurations. The document references a CK8-04 Pro clock generator and includes DDR-SO-DIMM and DDRAM-DIMM socket components. The schematic also indicates SLi mode selection via Pin 169 on connector J2 and normal mode selection via Pin 121 on connector J1.
Q: What is the date of this schematic?
A: Wednesday, July 06, 2005.
This Dell PowerEdge 4600 server memory card schematic, revision A01 dated May 21, 2004, is based on the Jaguar platform. The board number is 8Y810, with a PWB of 8Y811. Two PWA references are documented: H6267 for MSI and 8Y813 for Celestica. The assembly drawing is 8Y809. The memory architecture supports DDR RAM across six DIMM slots, organized as two memory cards (Card A and Card B) with separate I2C buses. The memory subsystem uses a REMC (Riser Expansion Memory Controller) with two DP (Data Path) devices in 225 PBGA packages. The design includes detailed clock routing, address/command termination, and VREF/VTT regulation. The stackup specifies 10-layer construction with specific impedance-controlled trace widths for 50-ohm and 100-ohm differential signals.
Q: What is the board number for this Dell PowerEdge 4600 memory card?
A: The schematic board number is 8Y810, revision A01.
Q: What memory architecture does this Dell PowerEdge 4600 memory card support?
A: It supports DDR memory across six DIMM slots, organized as two memory cards (Card A and Card B) with separate I2C buses.
Q: What are the PWA references for this memory card?
A: Two PWA references are documented: H6267 for MSI and 8Y813 for Celestica.
This Dell PowerEdge 4600 server motherboard, board number 8Y810 revision A02, is based on the Jaguar platform. The memory architecture supports up to 12 DDR DIMM slots across two memory cards, designated Card A and Card B. Each memory card utilizes a REMC DP0 and REMC DP1 interface, with DIMMs J1 through J12 distributed across the cards. The memory subsystem features dedicated I2C buses for each memory card, with specific I2C addresses assigned to each DIMM slot. The board uses a 10-layer PCB stackup with specific impedance-controlled routing for differential clock pairs and single-ended traces.
Q: What is the board number and revision for this Dell PowerEdge motherboard?
A: The board number is 8Y810, revision A02.
Q: What memory architecture does this motherboard support?
A: This motherboard supports a 6 DIMM per memory card architecture with two memory cards (Card A and Card B), totaling 12 DDR DIMM slots.
Q: What is the CPU platform used on this motherboard?
A: The CPU platform is Jaguar.
| Document Number | <Doc></TD> |
| Revision | <RevCode></TD> |
| Date | Wednesday, July 06, 2005 |
[TD]
| Brand | Dell |
| Model | PowerEdge 4600 |
| Motherboard Manufacturer | Dell Computer Corporation |
| Board Number | 8Y810 |
| Revision | A01 |
| Date | 5/21/2004 |
| CPU Platform | Jaguar |
| RAM Type | DDR |
| RAM Architecture | 6 DIMM |
| RAM Quantity / Slots | 6 |
| PWA (MSI) | H6267 |
| PWA (Celestica) | 8Y813 |
| PWB | 8Y811 |
| Assembly Drawing | 8Y809 |
| Brand | Dell |
| Revision | A02 |
| Date | 6/16/04 |
| RAM Type | DDR |
| RAM Quantity / Slots | 12 |
