msi ms-7283l2 ver 10
The MSI MS-7283L2 Ver:10 is an AMD AM2 (940) socket motherboard built around the NVIDIA C51G (Crush 51G) integrated graphics and MCP51/MCP51G southbridge chipset. The board features a 3-phase PWM voltage regulator using the Intersil ISL6566CRZ controller under VRM 10.1, with additional regulation provided by the W83310DS. System memory consists of four DDR SDRAM slots supporting 128-bit 400/533MHz operation. The LPC Super I/O and keyboard controller is handled by the Winbond W83627EHG, while audio is provided by the Analog Devices AD1986AJCPZ-REEL codec. Networking is supported by a Broadcom BCM4401/BCM5788 LAN controller. The BIOS is stored on a 4MB LPC Flash ROM. The board includes a dedicated AD7475 fan control IC.
A: The board number is MS-7283L2 Ver:10.
A: The EC/KBC is the Winbond W83627EHG LPC Super I/O.
A: The BIOS is stored on a 4MB LPC Flash ROM.
Q: What is the charging/power architecture?
A: The board uses a 3-phase PWM controller, the Intersil ISL6566CRZ, under VRM 10.1.
| Brand | MSI (Micro-Star Int'l Co., Ltd.) |
| Model | MS-7283 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO., LTD. |
| Board Number | MS-7283L2 Ver:10 |
| Revision | 10 |
| Date | Friday, April 21, 2006 |
| CPU Platform | AMD AM2 (940) |
| CPU Socket | Socket 940 (AMD K8 M2 940) |
| PCH / Southbridge | NVIDIA MCP51 / MCP51G (Crush 51G) |
| GPU Type | Integrated NVIDIA C51G |
| Graphics Architecture | NForce (C51G) |
| EC / KBC | W83627EHG |
| Audio Codec | AD1986AJCPZ-REEL / MONO |
| BIOS / SPI Flash | LPC FLASH ROM 4M |
| BIOS Flash Capacity | 4MB |
| Charging IC | ISL6566CRZ |
| Charger Architecture | 3-Phase PWM (VRM 10.1) |
| Power IC(s) | ISL6566CRZ 3 Phase PWM, W83310DS |
| RAM Type | DDR SDRAM |
| RAM Architecture | 128-bit 400/533MHz |
| RAM Quantity / Slots | 4 (DDR SDRAM CONN 0, 1, 2, 3) |
| LAN IC | BCM4401 / BCM5788 |
| Thermal Sensor | AD7475 |
MS-7283L2
AM2 940
940 AMD K8 M2 940
MCP51 / MCP51G CRUSH 51G
NForce (C51G)
W83627EHG
ISL6566CRZ
ISL6566CRZ 3 PHASE
W83310DS
DDR
BCM4401
BCM5788
AD7475
MS-7283L2
AM2 940
940 AMD K8 M2 940
NForce (C51G)
W83627EHG
ISL6566CRZ
ISL6566CRZ 3 PHASE
W83310DS
DDR
BCM4401
BCM5788
AD7475
