Schematic msi ms-7283l2 ver 0a schematic
BrandMSI (Micro-Star International)
ModelMS-7283
Revision0A
DateWednesday, February 22, 2006
CPU PlatformAMD 940 Athlon 64/Athlon 64 FX (Socket 940)
Chipset / SouthbridgeNVIDIA MCP51/MCP51G
GPU TypeNVIDIA C51G ([URL="https://dr-bios.com/components/graphics-models/crush-51g/"]Crush 51G)[/URL]
EC / KBCW83627EHF
Audio CodecAD1986A
BIOS / SPI FlashLPC FLASH ROM 4MB
LAN ICBCM4401/BCM5788
Charging ICISL6566CR
Power IC(s)ISL6566CR, W83310DS
RAM TypeDDR SDRAM
RAM Architecture128-bit 400/533MHz
RAM Quantity / Slots4 (DDR SDRAM CONN 0, 1, 2, 3)
Card Reader ICVT6307
[TD]Board Number[/TD][TD]MS-7283L2 Ver:0A[/TD][/TR]
The MSI MS-7283L2 Ver:0A is a Micro-Star International motherboard designed for the AMD 940 Athlon 64/Athlon 64 FX CPU platform using Socket 940. The board is built around the NVIDIA C51G (Crush 51G) integrated GPU and the NVIDIA MCP51/MCP51G southbridge chipset. System memory consists of four DDR SDRAM slots supporting a 128-bit 400/533MHz memory architecture. The embedded controller is a Winbond W83627EHF LPC Super I/O. Audio is handled by an Analog Devices AD1986A AC97 codec. Networking is provided by a Broadcom BCM4401/BCM5788 LAN controller. The BIOS is stored on a 4MB LPC Flash ROM. Power regulation is managed by an Intersil ISL6566CR 3-phase PWM controller and a Winbond W83310DS voltage regulator. A VIA VT6307 controller provides IEEE 1394 (FireWire) connectivity.
A: The board number is MS-7283L2 Ver:0A.
Q: What BIOS flash type is used on this motherboard?
A: The BIOS is stored on a 4MB LPC Flash ROM.
A: The embedded controller is a Winbond W83627EHF LPC Super I/O.
Q: What is the CPU platform and socket for this motherboard?
A: The CPU platform is AMD 940 Athlon 64/Athlon 64 FX using Socket 940.
A: The board supports four DDR SDRAM slots with a 128-bit 400/533MHz memory architecture.
  • MSI=MS-7283l2 Ver 0a.pdf
