msi ms-7210 rev 3.1
The MSI MS-7210 motherboard, revision Version 3.0, is built around the Intel LGA775-CPU platform supporting Intel Prescott, Cendar Mill, and Smithfield processors. The chipset consists of the Intel Lakeport GMCH northbridge and Intel ICH7/ICH7R southbridge. System memory is provided by four DDR II DIMM slots supporting a maximum of 4GB. The board utilizes a 4Mb FWH flash for BIOS storage. The Super I/O and keyboard controller is handled by the W83627EHF. Audio is provided by the ALC880 Azalia codec, while networking is managed by the RTL 8100/8110S PCI LAN controller. Power regulation is handled by the Intersil 6316CR 4-phase PWM controller and the Intersil 6614ACB driver. The board also features a VIA VT-6307/6308P controller for 1394 connectivity.
Q: What BIOS flash type is used on this motherboard?
A: The board uses a 4Mb FWH flash for BIOS storage.
Q: What Super I/O and keyboard controller is used?
A: The board uses the W83627EHF LPC Super I/O.
Q: What is the CPU socket and supported processor families?
A: The board uses an Intel LGA775 socket and supports Intel Prescott, Cendar Mill (65nm), and Smithfield (90nm Dual core) processors.
A: The board supports up to 4GB of DDR II memory across four DIMM slots.
| Brand | MSI |
| Model | MS-7210 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO., LTD. |
| Board Number | MS-7210 |
| Revision | Version 3.0 |
| Date | Tuesday, November 22, 2005 |
| CPU Platform | Intel LGA775-CPU |
| CPU Model | Intel Prescott ( L2=2MB ) - 3.8G / Intel Cendar Mill (65nm) - 3.73G & Above / Intel Smithfield (90nm Dual core) - 3.2G |
| PCH / Southbridge | Intel ICH7/ICH7R |
| GPU Type | Intel Lakeport - GMCH (North Bridge) |
| EC / KBC | W83627EHF |
| Audio Codec | ALC880 |
| BIOS / SPI Flash | FWH FLASH 4Mb |
| Charging IC | Intersil 6316CR |
| Power IC(s) | Intersil 6316 4Phase / Intersil 6614ACB |
| RAM Type | DDR II |
| RAM Architecture | DDR II * 4 (Max 4GB) |
| RAM Quantity / Slots | 4 |
| LAN IC | RTL 8100/8110S / RTL8100C/8110S |
| WiFi / WLAN IC | VIA VT-6307/6308P |
MS-7210
LGA775-CPU
ICH7
ICH7R
W83627EHF
ALC880
6316CR
6316 4PHASE
6614ACB
RTL8100/8110S
RTL8100C
VT-6307/6308P
MS-7210
LGA775-CPU
ICH7
ICH7R
W83627EHF
ALC880
6316CR
6316 4PHASE
6614ACB
RTL8100/8110S
RTL8100C
VT-6307/6308P
