msi ms-7210 rev 101
The MSI MS-7210 motherboard is an Intel LGA775 platform designed by MICRO-STAR INt'L CO., LTD., documented under Version 1 dated October 27, 2005. It supports Intel Prescott (L2=2MB) up to 3.8G, Cendar Mill (65nm) up to 3.73G and above, and Smithfield (90nm Dual core) up to 3.2G processors. The northbridge is the Intel Lakeport-GMCH, paired with an Intel ICH7/ICH7R southbridge. System memory consists of four DDR II DIMM slots. The board utilizes a 4Mb FWH flash for BIOS storage. The Super I/O and keyboard/mouse controller is the W83627EHF. Audio is handled by the Realtek ALC 880 Azalia codec, while networking is provided by the Realtek RTL8100C/8110S PCI LAN controller. The VRM is a 4-phase design using the Intersil 6316CR PWM controller. IEEE 1394 connectivity is supported via the VIA VT-6307/6308 controller.
Q: What type of BIOS flash is used on this motherboard?
A: The board uses a 4Mb FWH (Firmware Hub) flash for BIOS storage.
A: The Super I/O and keyboard/mouse controller is the W83627EHF.
Q: What is the VRM configuration on this motherboard?
A: The VRM is a 4-phase design using the Intersil 6316CR PWM controller.
| Brand | MSI |
| Model | MS-7210 |
| Motherboard Manufacturer | MICRO-STAR INt'L CO., LTD. |
| Document Number | MS-7210 |
| Revision | Version 1 |
| Date | Thursday, October 27, 2005 |
| CPU Platform | Intel LGA775-CPU |
| CPU Model | Intel Prescott ( L2=2MB ) - 3.8G / Intel Cendar Mill (65nm) - 3.73G & Above / Intel Smithfield (90nm Dual core) - 3.2G |
| PCH / Southbridge | Intel ICH7/ICH7R |
| GPU Type | Intel Lakeport -GMCH (North Bridge) |
| EC / KBC | W83627EHF |
| Audio Codec | ALC 880 |
| BIOS / SPI Flash | FWH FLASH 4Mb |
| Charging IC | Intersil 6316CR |
| RAM Type | DDR II |
| RAM Quantity / Slots | 4 |
| LAN IC | RTL8100C/8110S |
| Card Reader IC | VIA VT-6307/6308 |
LGA775-CPU
ICH7
ICH7R
W83627EHF
ALC880
6316CR
RTL8100C/8110S
VT-6307/6308
LGA775-CPU
ICH7
ICH7R
W83627EHF
ALC880
6316CR
RTL8100C/8110S
VT-6307/6308
