Schematic msi ms-6801 rev 0a schematic
msi ms-6801 rev 0a
BrandMicro-Star International Co., LTD.
DateMonday, November 11, 2002
CPU PlatformBCM4702
BIOS / SPI FlashAm29LV320D
BIOS Flash Exact ModelAm29LV320D
BIOS Flash ManufacturerAMD
BIOS Flash Capacity32Mbit
BIOS Flash PackageTSOP-48
RAM TypeSDRAM
RAM Architecture1M x 16
RAM Quantity / Slots2
LAN ICBCM4702
This Micro-Star International motherboard, dated November 11, 2002, is built around the Broadcom BCM4702 CPU platform, which also integrates the LAN controller. The system firmware is stored on an AMD Am29LV320D 32Mbit parallel NOR flash memory, housed in a TSOP-48 package. Main memory consists of two SDRAM devices, each organized as 1M x 16, providing a total of 4MB of system RAM. The board utilizes a 16-bit external interface (EIF) for flash and SDRAM communication, with configuration options for big-endian mode and 8-bit flash mode controlled by resistor settings on EIF_DATA_15 and EIF_DATA_14.
Q: What is the exact BIOS flash IC model used on this motherboard?
A: The BIOS flash IC is an AMD Am29LV320D, a 32Mbit parallel NOR flash in a TSOP-48 package.
Q: What type of RAM is used and how is it configured?
A: The board uses two SDRAM devices, each 1M x 16, for a total of 4MB of system memory.
Q: What is the main processor and LAN controller on this board?
A: The board uses a Broadcom BCM4702, which serves as both the CPU and the integrated LAN controller.
  • MSI=MS-6801 Rev 0a.pdf
