msi ms-6769 rev 0a
The MSI MS-6769 Rev A motherboard is designed for the Intel Willamette/Northwood 478-pin mPGA-B processor platform, utilizing the SiS 650GL North Bridge and SiS 962L South Bridge chipset. The board features a W83697HF LPC Super I/O for legacy and keyboard/mouse control, and a Realtek ALC650 AC'97 audio codec. Networking is provided by a RTL8201BL MII PHY LAN controller. Memory architecture supports two DDR DIMM slots and two SDRAM DIMM slots. The VRM is based on the Intersil HIP6302 controller, compliant with VRM 9.0 specifications. System clock generation is handled by an ICS952004AF clock generator.
A: The board number is MS-6769, revision A.
A: The LPC Super I/O and EC/KBC is the W83697HF.
A: The audio codec is the Realtek ALC650.
A: The LAN controller is the RTL8201BL MII PHY.
Q: What clock generator is used on this motherboard?
A: The main clock generator is the ICS952004AF.
| Brand | MSI (Micro-Star International) |
| Model | MS-6769 |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Board Number | MS-6769 |
| Revision | A |
| Date | Monday, January 20, 2003 |
| CPU Platform | Willamette/Northwood 478pin mPGA-B |
| CPU Socket | Socket 478 (mPGA-478B) |
| PCH / Southbridge | SiS 962L |
| GPU Type | [URL="https://dr-bios.com/components/graphics-models/sis-650gl/"]SiS 650GL (North Bridge)[/URL] |
| Graphics Architecture | SiS 650GL |
| EC / KBC | W83697HF |
| Audio Codec | Realtek ALC650 |
| LAN IC | RTL8201BL MII PHY |
| RAM Type | DDR / SDRAM |
| RAM Architecture | DDR * 2, SDRAM * 2 |
| RAM Quantity / Slots | DDR DIMM1 & DIMM2, SDR DIMM1 & DIMM2 |
| Charging IC | HIP6302 (VRM 9.0) |
| Power IC(s) | HIP6302 (Intersil) |
| Clock Generator | ICS952004AF |
MS-6769
Northwood
Willamette
478
962L
650GL
SiS 650GL
W83697HF
ALC650
RTL8201BL MII
DDR
SDRAM
HIP6302
HIP6302
ICS952004AF
MS-6769
Northwood
Willamette
478
962L
650GL
SiS 650GL
W83697HF
ALC650
RTL8201BL MII
DDR
SDRAM
HIP6302
HIP6302
ICS952004AF
