msi ms-6382 rev 20a
The MSI MS-6382 Rev 2.0 is a Micro-ATX motherboard built around the AMD Socket 462 (Socket A) platform, supporting AMD PGA 462 processors. The chipset consists of the VIA VT8366A Northbridge and the VIA VT8233 Southbridge. System memory is DDR-based with dedicated DDR termination circuitry. The board integrates a Winbond 83697HF-AW LPC Super I/O controller for legacy and I/O management. Audio is handled by an AC'97 Codec, and networking is provided by an IEEE 802.3 MAC with an MII interface. Graphics expansion is supported via an AGP 4X slot with Fast Write capability. The board also features a hardware monitor, six USB 1.1 ports, dual ATA 100 connectors, and a CNR riser slot.
A: The board number is MS-6382, revision 2.0.
Q: What CPU socket and platform does this motherboard use?
A: It uses an AMD PGA 462 Socket (Socket A) for AMD processors.
Q: What Super I/O controller is used on this board?
A: The Winbond 83697HF-AW LPC Super I/O controller is used.
Q: What type of system memory does this board support?
A: The board supports DDR memory with dedicated DDR termination circuitry.
| Brand | MSI (Micro-Star International) |
| Model | MS-6382 |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Board Number | MS-6382 |
| Revision | 2.0 |
| Date | Wednesday, May 15, 2002 |
| CPU Platform | AMD Socket 462 (Socket A) |
| CPU Socket | AMD PGA 462 Socket |
| PCH / Southbridge | VIA VT8233 |
| GPU Type | AGP 4X / Fast Write |
| EC / KBC | Winbond 83697HF-AW |
| Audio Codec | AC'97 Codec |
| RAM Type | DDR |
| RAM Architecture | DDR Terminations |
| LAN IC | IEEE 802.3 MAC (MII) |
| Form Factor | Micro-ATX |
