Schematic msi ms-56012 rev a schematic
msi ms-56012 rev a
BrandAMS
ModelAMS-56012
Project CodeAMS-56012
DateWednesday, July 19, 2006
CPU PlatformPP5023
Audio CodecAMS3514
Charging ICXC9216
RAM TypeSDRAM
RAM Architecture3.3V SDRAM
FM TunerSilicon Lab Si4700
StorageiNAND HYNIX 32MB
EEPROM24LC64
Micro SD CardMicro SD CARD
The AMS-56012 motherboard, dated July 19, 2006, is built around the PP5023 CPU platform. The system integrates an AMS3514 audio codec and a Silicon Lab Si4700 FM tuner module. Power management and charging are handled by an XC9216 switching regulator for the 3.3V rail. The board features 3.3V SDRAM memory architecture and utilizes a HYNIX 32MB iNAND for storage. An I2C EEPROM (24LC64) is present for configuration data, and a Micro SD card slot provides expandable storage. The design includes a docking connector, USB interface, and a keypad with slide switch controls.
Q: What is the main CPU platform used on this motherboard?
A: The motherboard uses the PP5023 CPU platform.
Q: What audio and FM tuner components are integrated?
A: The board integrates an AMS3514 audio codec and a Silicon Lab Si4700 FM tuner.
Q: What type of memory and storage does this board use?
A: The board uses 3.3V SDRAM and a HYNIX 32MB iNAND for storage.
  • MSI=MS-56012 Rev a .pdf
