MSI MS-1355 Rev 0A 0B 1.0 Schematic
The MSI MS-1355 revision 0A motherboard, dated Tuesday, October 06, 2009, is built around the Intel Arrandale Dual Core ULV CPU platform paired with the PCH HM55 southbridge. The system memory architecture is DDRIII Memory Down. The embedded controller is an ENE 3310C, and the audio codec is an ALC888. The BIOS is stored on a SPI flash device. Power management is handled by a TPS51125RGER charging IC, with additional power regulation from TPS51218, MAX8731A, SI4392, and ISL62881HRZ-T. Networking is provided by a Realtek RTL8111DL LAN IC. The board features an ENE6250 memory card reader and a PTN3300 HDMI level shifter.
Q: What is the board number and revision of this MSI motherboard?
A: The board number is MS-1355, revision 0A.
A: The EC/KBC is an ENE 3310C.
Q: What is the CPU platform and PCH for this motherboard?
A: The CPU platform is Arrandale Dual Core ULV, and the PCH is HM55.
A: The memory architecture is DDRIII Memory Down.
Q: What charging IC and power ICs are used?
A: The charging IC is TPS51125RGER, and power ICs include TPS51218, MAX8731A, SI4392, and ISL62881HRZ-T.
The MSI MS-1355 revision 0B motherboard, dated December 9, 2009, is built around the Intel Arrandale Dual Core ULV CPU platform paired with the PCH HM55 southbridge. The system utilizes an ENE 3310C EC/KBC communicating via SPI bus, with the BIOS also stored on a SPI flash device. Audio is handled by the Realtek ALC888 codec. Power management includes a TPS51125RGER charging IC with a DC selector architecture, supported by multiple power ICs such as the TPS51218, MAX8731A, SI4392, ISL62881HRZ-T, APL5913, and APL5331. Memory is configured as DDRIII 800MHz memory-down with a 128Mx8bits x16 configuration. The board integrates an ENE6250 memory card reader, a Realtek RTL8111DL LAN controller, WLAN/3G wireless support, and a DP139 HDMI level shifter.
Q: What EC/KBC is used on this MS-1355 motherboard?
A: The EC/KBC is an ENE 3310C, communicating via SPI bus.
A: The charging architecture uses a TPS51125RGER IC with a DC selector configuration.
Q: What type of memory does this board use?
A: The board uses DDRIII 800MHz memory-down, configured as 128Mx8bits x16.
Q: What audio codec is integrated on this motherboard?
A: The audio codec is a Realtek ALC888.
The MSI MS-1355 VER 1.0 motherboard is built around the Intel Arrandale Dual Core ULV CPU platform paired with the PCH HM55 southbridge. The system memory architecture supports DDRIII 800MHz via both SO-DIMM slots and memory down configurations. The embedded controller is an ENE 3310C, while the audio codec is an ALC888. Power management is handled by a combination of TPS51125RGER, TPS51218, MAX 8731A, ISL62881HRZ-T, and UP6308S regulators. The board features an SPI BIOS interface, a Realtek RTL8111DL LAN controller, an ENE6250 memory card reader, and a DP139 HDMI level shifter. Graphics output is provided through the integrated GPU via LVD interface.
A: The audio codec is an ALC888.
A: The charging IC is a TPS51125RGER.
Q: What memory card reader IC is used on this motherboard?
A: The memory card reader IC is an ENE6250.
Q: What HDMI level shifter is used on this motherboard?
A: The HDMI level shifter is a DP139.
| Brand | MSI |
| Model | MS-1355 |
| Motherboard Manufacturer | MSI CORPORATION |
| Board Number | MS-1355 |
| Revision | 0A |
| Date | Tuesday, October 06, 2009 |
| CPU Platform | Arrandale Dual Core ULV |
| PCH / Southbridge | PCH(HM55) |
| EC / KBC | ENE 3310C |
| Audio Codec | ALC888 |
| BIOS / SPI Flash | SPI |
| Charging IC | TPS51125RGER |
| Power IC(s) | TPS51218, MAX8731A, SI4392, ISL62881HRZ-T |
| RAM Architecture | Memory Down |
| LAN IC | RTL8111DL |
| Card Reader IC | ENE6250 |
| HDMI Level Shifter | PTN3300 |
| Brand | MSI |
| Model | MS-1355 |
| Revision | 0B |
| Date | Wednesday, December 09, 2009 |
| EC/KBC Package | SPI |
| Charger Architecture | DC Selector |
| Power IC(s) | TPS51218, MAX8731A, SI4392, ISL62881HRZ-T, APL5913, APL5331 |
| RAM Type | DDRIII 800MHZ |
| RAM Architecture | MEMORY DOWN |
| RAM Quantity / Slots | 128Mx8bits x16 |
| WiFi / WLAN IC | WLAN/3G |
| HDMI Level Shifter | DP139 |
| Brand | MSI |
| Model | MS-1355 |
| Revision | VER : 1.0 |
| Date | Friday, March 05, 2010 |
| Power IC(s) | TPS51218, MAX 8731A, ISL62881HRZ-T, UP6308S |
| RAM Architecture | SO-DIMM, Memory Down |
| GPU Type | Integrated (Arrandale) |
| Graphics Architecture | LVD |
MS-1355
Arrandale
HM55
3310C
ALC888
TPS51125RGER
ISL62881HRZ-T
MAX8731A
SI4392
TPS51218
RTL8111DL
ENE6250
PTN3300
APL5331
APL5913
WLAN / 3G
DP139
UP6308S
LVD
MS-1355
Arrandale
HM55
3310C
ALC888
TPS51125RGER
ISL62881HRZ-T
MAX8731A
SI4392
TPS51218
RTL8111DL
ENE6250
PTN3300
APL5331
APL5913
WLAN / 3G
DP139
UP6308S
LVD
