msi megabook l720 ms-1047 alviso rev 10
This MSI motherboard, dated August 19, 2005, is built around the Intel Socket 479 Dothan CPU platform. The system architecture is centered on the ICH6-M southbridge and the PCIe/NV43 Bridge 915GM graphics solution, utilizing an NV43M GPU. System management is handled by an ENE 3910 EC/KBC controller. Audio is provided by an ALC655 codec, while networking is managed by a Realtek RTL 8100C LAN IC. Storage connectivity is supported by an R5C593_CSP277 card reader controller. The charging subsystem is based on the MS1047 ALVISO architecture. Memory configuration consists of two DDR DRAM channels, designated Channel A and Channel B. Additional connectivity includes a GL850 USB hub IC and an MDC WLAN module. Thermal monitoring is managed by a 277 thermal sensor.
A: The motherboard uses an ENE 3910 EC/KBC controller.
A: The charging IC is an MS1047, and the charger architecture is ALVISO.
Q: What audio codec is used?
A: The audio codec is an ALC655.
Q: What LAN IC is used?
A: The LAN IC is a Realtek RTL 8100C.
| Brand | MSI |
| Motherboard Manufacturer | MSI CORPORATION |
| Date | Friday, August 19, 2005 |
| CPU Platform | Intel Socket 479 Dothan |
| PCH / Southbridge | ICH6-M |
| GPU Type | NV43M |
| Graphics Architecture | PCIe/NV43 Bridge 915GM |
| EC / KBC | ENE 3910 |
| Audio Codec | ALC655 |
| LAN IC | RTL 8100C |
| Card Reader IC | R5C593_CSP277 |
| Charging IC | MS1047 |
| Charger Architecture | ALVISO |
| RAM Type | DDR DRAM |
| RAM Architecture | Channel A / Channel B |
| WiFi / WLAN IC | MDC |
| USB Hub IC | GL850 |
| Thermal Sensor | 277 |
| Power IC(s) | CPGACHARGER |
