Microsoft Surface Pro 3 X896238-001 Schematic
The Pegatron CASTLE2 motherboard, revision 1.02 dated July 8, 2014, is engineered around an Intel Broadwell processor platform. The system EC is an ITE 8528, with its firmware stored on an MX25L4006EZNI-12G EEPROM. The main UEFI BIOS is stored on a 16MB SPI ROM, using either a W25Q128FVSIQ or W25Q128FVPIQ IC. System memory consists of 4GB or 8GB of LPDDR3 at 1600MHz, configured as two x32 IB DRAM packages. Audio is handled by a Realtek ALC3264 codec, and battery charging is managed by a BQ24735 controller. Wireless connectivity is provided by a Marvell 8897 module supporting 802.11 a/b/g/n/ac and Bluetooth 4.0. The board includes a Realtek RTS5304 Micro SD card controller, an ATUC128L3U-Z3UR sensor aggregator microcontroller, and an ATECC108 authentication IC. Thermal monitoring is performed by STTS751-1DP3F sensors, and the board features an ST LSM330 accelerometer and gyroscope, a MEMSIC MMC34160PJ e-compass, and an Intersil ISL29033 ambient light and proximity sensor.
Q: What BIOS IC models are used on this motherboard?
A: The main UEFI BIOS is stored on a 16MB SPI ROM, using either a W25Q128FVSIQ or W25Q128FVPIQ.
Q: What EC/KBC is used and is it programmable?
A: The system EC is an ITE 8528. The EC firmware is stored on a separate MX25L4006EZNI-12G EEPROM, and the block diagram indicates an EC Debug UART and SAM SPI reflash capability, supporting programming.
A: The battery charge controller is a BQ24735.
| Brand | Pegatron Corp. |
| Project Name | CASTLE2 |
| Revision | 1.02 |
| Date | Tuesday, July 08, 2014 |
| Engineer | JDM1Custom376 |
| CPU Platform | BROADWELL Intel Processor |
| EC / KBC | ITE 8528 |
| EC Flash / ROM | MX25L4006EZNI-12G |
| BIOS / SPI Flash | W25Q128FVSIQ or W25Q128FVPIQ |
| BIOS Flash Capacity | 16MB |
| Audio Codec | Realtek ALC3264 |
| Charging IC | BQ24735 |
| RAM Type | LPDDR3 |
| RAM Architecture | 4GB/8GB LPDDR3 @1600MHz IB DRAM x32 (2 pieces) |
| WiFi / WLAN IC | Marvell 8897 WLAN 802.11 /b/g/n/AC Bluetooth 4.0 |
| Card Reader IC | Realtek RTS5304 |
| Thermal Sensor | STTS751-1DP3F |
| Hall Effect Sensor IC | ROHM BU52058GWZ-E2 |
| Sensor Aggregator Microcontroller | ATUC128L3U-Z3UR |
| Authentication IC | ATECC108 |
| Accelerometer+Gyro | ST LSM330 |
| E-compass (Magnetometer) | MEMSIC MMC34160PJ |
| ALS/Proximity Sensor | Intersil ISL29033 |
| Audio IC | AUDIENCE ES320 |
| TPM | SLB9665T |
CASTLE2
Broadwell
8528
MX25L4006EZNI-12G
W25Q128FVSIQ OR W25Q128FVPIQ
ALC3264
BQ24735
LPDDR3
8897 WLAN 802.11
AC Bluetooth 4.0
RTS5304
STTS751-1DP3F
AUDIENCE ES320
SLB9665T
CASTLE2
Broadwell
8528
MX25L4006EZNI-12G
ALC3264
BQ24735
LPDDR3
8897 WLAN 802.11
AC Bluetooth 4.0
RTS5304
STTS751-1DP3F
AUDIENCE ES320
SLB9665T
