lenovothinkpad e125 fl8fl9-c
This Quanta Computer Inc. D/M NOTE INTEL HURON RIVER project, documented under number 5544332211DDCCBBAA revision A1 dated January 31, 2011, is built around the Intel Huron River platform featuring a Sandy Bridge CPU and Cougar Point HM65 PCH. The system employs an IT8518/19 embedded controller for KBC and power management functions. BIOS storage is provided by a 4MB SPI flash, with a separate 512K SPI flash dedicated to EC firmware. Audio is handled by a CX20671-21Z codec, while networking is supported by an AR8151-BL1A-R++ Ethernet controller and a RTL8111E-VB-GR WLAN module. The charging subsystem is managed by an ISL88731A charger IC, and power regulation is distributed across RT8206MGQW, OZ8117, ISL95831, and TPS51116 regulators. Memory configuration consists of two DDR3 SO-DIMM slots. A Realtek RTS5209 controller provides card reader functionality.
A: The motherboard uses a 4MB SPI Flash for the main BIOS and a separate 512K SPI Flash for the EC/KBC firmware.
A: The motherboard uses an IT8518/19 embedded controller for keyboard, touchpad, and power management functions.
A: The charging IC is an ISL88731A.
Q: What is the memory configuration on this motherboard?
A: The motherboard supports DDR3 memory in two SO-DIMM slots.
| Project Code | D/M NOTE INTEL HURON RIVER |
| Document Number | 5544332211DDCCBBAA |
| Revision | A1 |
| Date | Monday, January 31, 2011 |
| CPU Platform | Intel Huron River Sandy Bridge |
| PCH / Southbridge | Cougar Point HM65 |
| EC / KBC | IT8518/19 |
| Audio Codec | CX20671-21Z |
| BIOS / SPI Flash | SPI Flash (4MB) |
| EC Flash / ROM | SPI Flash (512K) |
| Charging IC | ISL88731A |
| Power IC(s) | RT8206MGQW, OZ8117, ISL95831, TPS51116 |
| Card Reader IC | Realtek RTS5209 |
| LAN IC | AR8151-BL1A-R++ |
| WiFi / WLAN IC | RTL8111E-VB-GR |
