lenovo thinkpad x220 wistron dasher-1 ldb-1 schematic 1
The Wistron Dasher-1 (Project Code Dasher-1, Board Number A31101, Revision A3, dated January 12, 2011) is built on the Intel Sandy Bridge CPU platform with an Intel Cougar Point PCH. Graphics are provided by the integrated Intel Sandy Bridge graphics core. The system uses an SPI-FLASH for BIOS storage and is managed by a Thinker-1 EC/KBC. Memory architecture consists of dual-channel unbuffered DDR3 1333MHz SODIMMs across two slots. Power management includes a BQ24742 battery charger/selector and multiple DC/DC converters such as the TPS51220ARSN, VT1316/VT1317, VT357FCX, VT356FCX, MAX1510, and TPS62060. Connectivity is supported by an ALC audio codec, a USB2514B USB hub, an Intel LEWISVILLE WLAN card, a Rinken-2 LAN IC, and a PI3L500AZFEX HDMI level shifter. Thermal monitoring is handled by an EMC1428 sensor, and a R4F2113 IC manages the media card reader interface.
A: The board number is A31101, and the project code is Dasher-1.
Q: What CPU platform and PCH does this motherboard use?
A: It uses the Intel Sandy Bridge CPU platform with an Intel Cougar Point PCH.
A: The EC/KBC is the Thinker-1.
A: It supports dual-channel unbuffered DDR3 1333MHz SODIMMs across two slots.
A: The charging IC is the BQ24742 battery charger/selector.
| Model | Dasher-1 |
| Project Code | Dasher-1 |
| Board Number | A31101 |
| Revision | A3 |
| Date | Wednesday, January 12, 2011 |
| CPU Platform | Intel Sandy Bridge |
| GPU Type | Integrated Graphics |
| Graphics Architecture | Intel Sandy Bridge Integrated Graphics |
| EC / KBC | Thinker-1 |
| Audio Codec | ALC |
| BIOS / SPI Flash | SPI-FLASH |
| Charging IC | BQ24742 |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51220ARSN, VT1316/VT1317, VT357FCX, VT356FCX, MAX1510, TPS62060 |
| RAM Type | DDR3 1333MHz |
| RAM Architecture | Dual Channel, Unbuffered DDR3 SODIMM |
| Thermal Sensor | EMC1428 |
| Card Reader IC | R4F2113 |
| USB Hub IC | USB2514B |
| LAN IC | Rinken-2 |
| WiFi / WLAN IC | Intel LEWISVILLE |
| HDMI Level Shifter | PI3L500AZFEX |
DASHER-1
A31101
Sandy Bridge
THINKER-1
BQ24742
MAX1510
TPS51220ARSN
TPS62060
VT1316
VT1317
VT356FCX
VT357FCX
EMC1428
R4F2113
USB2514B
RINKEN-2
PI3L500AZFEX
DASHER-1
A31101
Sandy Bridge
THINKER-1
BQ24742
MAX1510
TPS51220ARSN
TPS62060
VT1316
VT1317
VT356FCX
VT357FCX
EMC1428
R4F2113
USB2514B
RINKEN-2
PI3L500AZFEX
