lenovo thinkpad x100 x100e fl3b-mknote congo rev 1a schematic 1
This Quanta Congo project motherboard is designed for the AMD Congo platform, featuring an AMD ASB1r2 Conesus northbridge in a 27mm 812-pin BGA package paired with an SB710 southbridge. Graphics are handled by an RS780M GPU in a 21mm 528-pin BGA package. The system uses DDR2 SO-DIMM memory across two slots. The embedded controller is an ITE8502, and the audio codec is an ALC269VB. Networking is provided by a Realtek RTL8111DL Gigabit Ethernet controller, while a Realtek RTL5159 handles the card reader functionality. The SPI flash is used for BIOS storage. The clock generation is managed by an SLG8SP628 IC. The PCB stack-up consists of 8 layers.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an ITE8502.
A: The audio codec is an ALC269VB.
A: The LAN controller is a Realtek RTL8111DL 10/100/1G Ethernet.
Q: What card reader controller is used on this motherboard?
A: The card reader controller is a Realtek RTL5159.
| Project Code | Congo |
| Date | Friday, September 11, 2009 |
| CPU Platform | AMD Congo |
| Northbridge | AMD ASB1r2 Conesus 27mmX27mm 812pin BGA |
| Southbridge | SB710 21mmX21mm 528pin BGA |
| GPU Type | RS780M 21mmX21mm 528pin BGA |
| EC / KBC | ITE8502 |
| Audio Codec | ALC269VB |
| LAN IC | Realtek RTL8111DL 10/100/1G Ethernet |
| Card Reader IC | Realtek RTL5159 |
| RAM Type | DDR2 SO-DIMM |
| Charging IC | USB Charger |
| Thermal Sensor | Thermal Sensor |
| WiFi / WLAN IC | WLAN Module |
| Clock Generator | SLG8SP628 |
| PCB Layer Count | 8 |
