lenovo thinkpad x100 x100e fl3 1022 c 2350 schematic 1
This Quanta Congo project motherboard is built around the AMD Congo platform, featuring an AMD ASB1r2 Conesus northbridge (27mm x 27mm 812pin BGA) paired with an SB710 southbridge (21mm x 21mm 528pin BGA). Graphics are handled by the integrated RS780M GPU (21mm x 21mm 528pin BGA). The system uses DDR2 SO-DIMM memory across two slots and includes an SPI flash for BIOS storage. The embedded controller is an ITE8502, and audio is managed by a Realtek ALC269VB codec. Networking is provided by a Realtek RTL8111DL 10/100/1000 Ethernet controller, with WLAN connectivity via a Mini PCIe module. A Realtek RTL5159 card reader is present, along with an APS accelerometer and a thermal sensor. The clock generation is handled by an SLG8SP628 IC in a QFN64 package. The PCB is an 8-layer stackup.
Q: What is the embedded controller (EC) used on this motherboard?
A: The EC is an ITE8502.
A: The audio codec is a Realtek ALC269VB.
Q: What is the LAN controller on this motherboard?
A: The LAN controller is a Realtek RTL8111DL 10/100/1000 Ethernet controller.
A: This motherboard supports DDR2 SO-DIMM memory across two slots.
| Project Code | Congo |
| Date | Thursday, October 22, 2009 |
| CPU Platform | AMD Congo |
| Northbridge | AMD ASB1r2 Conesus 27mm x 27mm 812pin BGA |
| Southbridge | SB710 21mm x 21mm 528pin BGA |
| GPU Type | RS780M 21mm x 21mm 528pin BGA |
| EC / KBC | ITE8502 |
| Audio Codec | ALC269VB |
| LAN IC | Realtek RTL8111DL 10/100/1G Ethernet |
| Card Reader IC | Realtek RTL5159 |
| RAM Type | DDR2 SO-DIMM |
| Thermal Sensor | Yes |
| Clock Generator | SLG8SP628 (QFN64) |
| Charging IC | USB Charger |
| WiFi / WLAN IC | WLAN Module (Mini PCIe) |
| Accelerometer | APS (Accelerometer) |
| PCB Layer Count | 8 |
