Lenovo ThinkPad L13 Lar-1 18834-1M Schematic
This Wistron Ares-1 (LAR-1) Cometlake-U motherboard, project code 4PD0HK010001, uses board number 18834-1 and document number A4199, dated 2020-03-19. The platform is Intel Cometlake-U with DDR4 memory down architecture. The embedded controller is an NPCE288. The system uses a 16MB SPI flash for BIOS. Audio is handled by a Synaptics CX11880-11Z codec. Power management includes a BQ25710ARSNR battery charger/selector and multiple DC/DC converters from Texas Instruments and ON Semiconductor. The integrated LAN is an Intel 219LM/V, and wireless connectivity is provided by an Intel Jefferson Peak module. A Realtek RTS5232S-GR card reader and a Parade PS8747B USB hub are present. HDMI connectivity uses a Parade PS8407A re-driver. Thermal monitoring is managed by NCT7717U and NCT7718W sensors.
A: The embedded controller is an NPCE288.
Q: What is the BIOS flash capacity and type?
A: The BIOS is stored on a 16MB SPI flash.
Q: What charging IC and architecture does this board use?
A: The charging IC is a BQ25710ARSNR, configured as a battery charger/selector.
A: The board uses DDR4 memory down architecture.
| Project Code | 4PD0HK010001 |
| Board Number | 18834-1 |
| Revision | LAR-1 |
| Date | 2020-03-19 |
| CPU Platform | Cometlake-U |
| EC / KBC | NPCE288 |
| Audio Codec | CX11880-11Z |
| BIOS / SPI Flash | SPI Flash 16MB |
| BIOS Flash Capacity | 16MB |
| Charging IC | BQ25710ARSNR |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51393RJER, TPS51395RJER, TPS51486RJER, TPS51396RJER, NCP302045LMNTWG, NCP81253MNTBG, NCP81218MNTXG, NCP302035LMNTWG, RT5797ALGQW |
| RAM Architecture | MEMORY DOWN |
| LAN IC | Intel 219LM/V |
| WiFi / WLAN IC | Jefferson Peak |
| Card Reader IC | RTS5232S-GR |
| USB Hub IC | PS8747B |
| HDMI Level Shifter | PS8407A |
| Thermal Sensor | NCT7717U, NCT7718W |
| Document Number | A4199 |
4PD0HK010001
18834-1
Comet Lake-U
NPCE288
CX11880-11Z
BQ25710ARSNR
NCP302035LMNTWG
NCP302045LMNTWG
NCP81218MNTXG
NCP81253MNTBG
RT5797ALGQW
TPS51393RJER
TPS51395RJER
TPS51396RJER
TPS51486RJER
219LM/V
RTS5232S-GR
PS8747B
PS8407A
NCT7717U
NCT7718W
4PD0HK010001
18834-1
Comet Lake-U
NPCE288
CX11880-11Z
BQ25710ARSNR
NCP302035LMNTWG
NCP302045LMNTWG
NCP81218MNTXG
NCP81253MNTBG
RT5797ALGQW
TPS51393RJER
TPS51395RJER
TPS51396RJER
TPS51486RJER
219LM/V
RTS5232S-GR
PS8747B
PS8407A
NCT7717U
NCT7718W
