Lenovo ThinkPad L13 Lar-1 18834-1M Schematic
The Wistron Ares-1 (LAR-1) motherboard, project code 4PD0HK010001, is based on the Cometlake-U platform with an Intel PCH-LP southbridge. The board number is 18834-1, documented under A4199, dated March 19, 2020. It utilizes an NPCE288 embedded controller and features dual SPI flash configurations of 16MB and 32MB. The audio subsystem is handled by a CX11880-11Z codec. Power management includes a BQ25710ARSNR battery charger/selector and multiple DC/DC converters such as the NCP302045LMNTWG, NCP81253MNTBG, NCP81218MNTXG, TPS51393RJER, TPS51395RJER, TPS51396RJER, TPS51486RJER, and RT5797ALGQW. Memory architecture is DDR4 memory down with Channel A and Channel B. The board integrates an Intel 219LM/V GbE PHY, Jefferson Peak WLAN, an RTS5232S-GR card reader, and a PS8407A HDMI re-driver.
A: The schematic references two SPI flash configurations: one 16MB and one 32MB.
A: The embedded controller is an NPCE288.
Q: What is the charging architecture on this motherboard?
A: The charging architecture uses a BQ25710ARSNR battery charger/selector.
A: The memory architecture is DDR4 memory down with Channel A and Channel B.
| Model | Ares-1 (LAR-1) |
| Project Code | 4PD0HK010001 |
| Board Number | 18834-1 |
| Revision | LAR-1 |
| Date | 2020-03-19 |
| CPU Platform | Cometlake-U |
| Platform Alias | Ares-1 (LAR-1) |
| PCH / Southbridge | PCH-LP |
| EC / KBC | NPCE288 |
| Audio Codec | CX11880-11Z |
| BIOS / SPI Flash | SPI Flash 16MB, SPI Flash 32MB |
| Charging IC | BQ25710ARSNR |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | NCP302045LMNTWG, NCP81253MNTBG, NCP81218MNTXG, TPS51393RJER, TPS51395RJER, TPS51396RJER, TPS51486RJER, RT5797ALGQW |
| RAM Architecture | DDR4 MEMORY DOWN |
| RAM Quantity / Slots | CHANNEL A, CHANNEL B |
| Card Reader IC | RTS5232S-GR |
| LAN IC | Intel 219LM/V |
| WiFi / WLAN IC | Jefferson Peak |
| HDMI Level Shifter | PS8407A |
| Document Number | A4199 |
4PD0HK010001
18834-1
Comet Lake-U
ARES-1 LAR-1
NPCE288
CX11880-11Z
BQ25710ARSNR
NCP302045LMNTWG
NCP81218MNTXG
NCP81253MNTBG
RT5797ALGQW
TPS51393RJER
TPS51395RJER
TPS51396RJER
TPS51486RJER
RTS5232S-GR
219LM/V
PS8407A
4PD0HK010001
18834-1
Comet Lake-U
ARES-1 LAR-1
NPCE288
CX11880-11Z
BQ25710ARSNR
NCP302045LMNTWG
NCP81218MNTXG
NCP81253MNTBG
RT5797ALGQW
TPS51393RJER
TPS51395RJER
TPS51396RJER
TPS51486RJER
RTS5232S-GR
219LM/V
PS8407A
