lenovo n200 n440 anote2.0 06234-1 4t001 svt rev-1 schematic 1
This Wistron Corporation motherboard, project code 91.4T001.001, board number A3156 revision -1, is built around the Intel Meron 2M/4M SV CPU platform with an ICH8-M southbridge. The graphics subsystem supports both UMA and discrete solutions, utilizing an Nvidia G72MV GPU. System management is handled by the WPC8763L EC/KBC, while audio is provided by the CX20548 HD Audio Codec. The board features 1MB of Flash ROM for BIOS storage. Power management is managed by a combination of ISL6255 charging IC, ISL6268CAZ, ISL6262ACRZ, TPS51120, and TPS51116 power ICs. Memory configuration includes two DDRII 533/667 slots supporting dual-channel architecture. Connectivity is provided by the BCM5906 or BCM5787M LAN IC and the WBC8763L 802.11a/b/g/n WiFi module. The Ricoh R5C832 handles card reader duties. The PCB number is 06234.
A: The motherboard uses a 1MB Flash ROM for BIOS storage.
A: The motherboard uses the WPC8763L EC/KBC.
Q: Does this motherboard support both UMA and discrete graphics?
A: Yes, the schematic indicates support for both UMA and discrete graphics solutions, with the discrete option using an Nvidia G72MV GPU.
A: The charging IC is the ISL6255.
| Project Code | 91.4T001.001 |
| Board Number | A3156 |
| Revision | -1 |
| Date | Thursday, March 22, 2007 |
| CPU Platform | Intel Meron 2M/4M SV |
| PCH / Southbridge | ICH8-M |
| GPU Type | Nvidia G72MV |
| Graphics Architecture | UMA solution / Discrete solution |
| EC / KBC | WPC8763L |
| Audio Codec | CX20548 |
| BIOS / SPI Flash | 1MB Flash ROM |
| Charging IC | ISL6255 |
| Power IC(s) | ISL6268CAZ, ISL6262ACRZ, TPS51120, TPS51116 |
| RAM Type | DDRII 533/667 |
| RAM Architecture | DDR II 667 Channel A, DDR II 667 Channel B |
| RAM Quantity / Slots | Slot 1, Slot 2 |
| Card Reader IC | Ricoh R5C832 |
| LAN IC | BCM5906 / BCM5787M |
| WiFi / WLAN IC | WBC8763L 802.11a/b/g/n |
| PCB Number | 06234 |
91.4T001.001
A3156
4M SV
Meron 2M
ICH8
G72MV
WPC8763L
CX20548
ISL6255
ISL6262ACRZ
ISL6268CAZ
TPS51116
TPS51120
RICOH R5C832
BCM5787M
BCM5906
WBC8763L 802.11a
06234
91.4T001.001
A3156
4M SV
Meron 2M
ICH8
G72MV
WPC8763L
CX20548
ISL6255
ISL6262ACRZ
ISL6268CAZ
TPS51116
TPS51120
RICOH R5C832
BCM5787M
BCM5906
WBC8763L 802.11a
06234
