Schematic Lenovo Legion R7000P NM-D281 Schematic
BrandLC Future Center
ModelY550
Motherboard ManufacturerLC Future Center
Board NumberNM-D281
Revision0.1
Date2020-04-12
CPU PlatformAMD APU Renoir
GPU TypenVidia N18E-G0/G1
EC / KBCITE IT8227-LQFP128
Audio CodecALC3287
BIOS / SPI Flash16MB
Charging ICCRTS5457P
RAM TypeDDR4
RAM ArchitectureDDR4 non-ECC
RAM Quantity / SlotsDDR4-SO-DIMM x2
Thermal SensorF75303M
Card Reader ICUSB3.0 & Card reader
USB Hub ICUSB Hub
LAN ICRealtek RTL8111H-CG
WiFi / WLAN ICM.2 Card (WLAN&BT)
HDMI Level ShifterHDMI Conn.
This LC Future Center Y550 motherboard, board number NM-D281 revision 0.1 dated 2020-04-12, is built around the AMD APU Renoir platform paired with an nVidia N18E-G0/G1 discrete GPU. The system memory architecture consists of DDR4 non-ECC memory via two DDR4-SO-DIMM slots. The embedded controller is an ITE IT8227-LQFP128, and the audio codec is an ALC3287. The BIOS/SPI flash is a 16MB IC. Networking is handled by a Realtek RTL8111H-CG LAN IC, with wireless connectivity provided by an M.2 WLAN&BT card. The charging IC is a CRTS5457P, and thermal monitoring is managed by an F75303M sensor. The board includes a USB3.0 & Card reader controller, a USB Hub IC, and an HDMI connector.
A: The embedded controller is an ITE IT8227-LQFP128.
Q: What is the BIOS flash capacity?
A: The BIOS/SPI flash is a 16MB IC.
A: The memory architecture is DDR4 non-ECC, using two DDR4-SO-DIMM slots.
Q: What is the charging IC?
A: The charging IC is a CRTS5457P.
Q: What LAN IC is used?
A: The LAN IC is a Realtek RTL8111H-CG.
  • Lenovo Legion R7000P NM-D281 Schematic.pdf
