lenovo ideapad miix 10 jazz 0513b bom vixjfull permission schematic 1
The Compal LA-A141P is an Intel Clover View platform motherboard designed by Compal Electronics, Inc., dated 2013-03-25 with revision 0.3. The system is powered by a TI BQ24193 charger supporting an S4P 25Whr battery configuration, with fuel gauging managed by a TI BQ27541-C2. Main power regulation is handled by a TI PSNB5072A1Z. The board features 2GB of LPDDR2 memory in a CO-POP architecture. The embedded controller is an ST STM32F103CBU6TR. Audio is provided by a Realtek ALC5640 codec. The BIOS SPI flash is a Winbond W25X40C with 4Mbit capacity. Connectivity includes a TI TUSB1211 USB PHY, a Broadcom BCM47511 GPS module, and an AzureWave AW-CM3218 WLAN/BT combo module. HDMI output is supported via a Renesas UPD60802A level shifter. Storage is handled by a Realtek Samsung KLMCG8GE4A-A001 eMMC device.
A: The BIOS SPI flash is a Winbond W25X40C with 4Mbit capacity.
A: The embedded controller is an ST STM32F103CBU6TR.
Q: What is the charging architecture of this motherboard?
A: The charging IC is a TI BQ24193, supporting an S4P 25Whr battery configuration with a TI BQ27541-C2 fuel gauge.
Q: What memory configuration does this motherboard use?
A: The board uses 2GB of LPDDR2 memory in a CO-POP architecture.
| Model | LA-A141P |
| Board Number | LA-A141P |
| Revision | 0.3 |
| Date | 2013-03-25 |
| CPU Platform | Intel Clover View |
| EC / KBC | ST STM32F103CBU6TR |
| Audio Codec | Realtek ALC5640 |
| BIOS / SPI Flash | Winbond W25X40C |
| BIOS Flash Exact Model | W25X40C |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 4Mbit |
| Charging IC | TI BQ24193 |
| Charger Architecture | S4P 25Whr |
| Power IC(s) | TI BQ27541-C2, TI PSNB5072A1Z |
| RAM Type | LPDDR2 |
| RAM Architecture | CO-POP |
| RAM Quantity / Slots | 2GB |
| Card Reader IC | Realtek Samsung KLMCG8GE4A-A001 |
| USB Hub IC | TI TUSB1211 |
| LAN IC | Broadcom BCM47511 |
| WiFi / WLAN IC | AzureWave AW-CM3218 |
| HDMI Level Shifter | Renesas UPD60802A |
LA-A141P
Clover View
ST STM32F103CBU6TR
ALC5640
W25X40C
BQ24193
BQ27541-C2
PSNB5072A1Z
LPDDR2
KLMCG8GE4A-A001
TUSB1211
BCM47511
AzureWave AW-CM3218
UPD60802A
LA-A141P
Clover View
ST STM32F103CBU6TR
ALC5640
W25X40C
BQ24193
BQ27541-C2
PSNB5072A1Z
LPDDR2
KLMCG8GE4A-A001
TUSB1211
BCM47511
AzureWave AW-CM3218
UPD60802A
