Schematic Lenovo Ideapad Gaming 15IAH7 LA-L911P Schematic
BrandCompal
ModelLA-L911P
Project CodeLA-L911P
Board NumberLA-L911P
Revision1.0
Date2021-11-11
CPU PlatformIntel Alder Lake-H45 Processor
CPU ModelAlder Lake-P (H45) BGA1744 Type3 45W 6C 8A + GT 250 mm x 25 mm
GPU TypeGN20-P0 [URL="https://dr-bios.com/components/graphics-models/rtx/"](RTX 3050)[/URL] / GN20-P1 (RTX 3050 Ti)
Graphics ArchitectureNvdia GPU
EC / KBCIT8176
EC/KBC PackageMCU with KB Controller
Audio CodecRealtek ALC3287
BIOS / SPI FlashW25Q16JWSSIQ
BIOS Flash Exact ModelW25Q16JWSSIQ
BIOS Flash Capacity8MB
EC Flash / ROMW25Q80DVSSIG
Charging ICTPS65993AEA
Charger ArchitecturePower Delivery
RAM TypeDDR4 3200MHz
RAM ArchitectureDDR4 SO-DIMM X1 + B-ch Memory Down X 4
RAM Quantity / SlotsDDR4-SO-DIMM X1
LAN ICRealtek RTL8111H-CG
WiFi / WLAN ICCNVi
HDMI Level ShifterTCP
Card Reader ICKB9542Q
USB Hub ICPS8719B
Thermal SensorFreesync
Compatible BIOS IC ModelsW25R256JVEIQ
This Compal LA-L911P schematic, revision 1.0 dated November 11, 2021, documents a motherboard designed for the Intel Alder Lake-H45 processor platform. The CPU is an Alder Lake-P (H45) BGA1744 Type3 45W 6C 8A + GT. Graphics are handled by an Nvidia GPU, specifically the GN20-P0 (RTX 3050) or GN20-P1 (RTX 3050 Ti). The embedded controller is an IT8176 MCU with keyboard controller. System memory consists of DDR4 3200MHz, configured as one DDR4 SO-DIMM slot plus four B-ch memory down chips. The primary BIOS SPI flash is an 8MB W25Q16JWSSIQ, with a compatible model listed as W25R256JVEIQ. A separate EC flash ROM, the W25Q80DVSSIG, is also present. The charging architecture uses a TPS65993AEA Power Delivery controller. The audio codec is a Realtek ALC3287, and the LAN controller is a Realtek RTL8111H-CG. The board also features a PS8719B USB hub IC and a KB9542Q card reader controller.
A: The primary BIOS SPI flash is an 8MB W25Q16JWSSIQ. A compatible model, the W25R256JVEIQ, is also listed in the block diagram.
  • Lenovo Ideapad Gaming 15IAH7 LA-L911P Schematic.pdf
