Schematic Lenovo Flex LC55-14A 19793-1 Schematic
BrandWistron Corporation
Project Code4PD0K101A001
Board NumberLC55-14A-1
RevisionA3
DateWednesday, March 04, 2020
CPU PlatformAMD APU (Renoir)
GPU TypeIntegrated (AMD APU)
EC / KBCNuvoton NPCE386
Audio CodecRealtek ALC3287
BIOS / SPI Flash16MB Quad Read Flash ROM
Charging ICBQ25700ARSNR
Power IC(s)RT3663BMGQW, RT8231CGQW, APL5934KAI-TR, RT5797ALGQW, TPS51395PRJER, TPS51393PRJER, RT8231AGQW
RAM TypeDDR4 3200MHz
RAM ArchitectureMemory down (SDP / DDP)
RAM Quantity / Slotsx4 pcs per channel (Channel A and Channel B)
Card Reader ICRealtek Card Reader Controller
USB Hub ICRealtek RTS5457
LAN ICRealtek RTS5457 (USB-C Controller)
WiFi / WLAN ICNGFF WLAN
HDMI Level ShifterPS8319B (Re-driver)
The Wistron LC55-14A-1 (Project Code 4PD0K101A001, Revision A3) is an AMD Renoir APU-based motherboard featuring integrated graphics. The system is managed by a Nuvoton NPCE386 EC/KBC and boots from a 16MB Quad Read SPI Flash ROM. Memory is provided by DDR4 3200MHz modules in a memory-down configuration, with four pieces per channel across Channel A and Channel B. Power management is handled by a BQ25700ARSNR battery charger and multiple DC/DC converters including RT3663BMGQW, RT8231CGQW, APL5934KAI-TR, RT5797ALGQW, TPS51395PRJER, TPS51393PRJER, and RT8231AGQW. Audio is driven by a Realtek ALC3287 codec, while connectivity includes a Realtek RTS5457 USB-C controller and PS8319B re-drivers for HDMI. Storage is supported via an NGFF/NvMe SSD slot and an NGFF WLAN module.
A: The motherboard uses a Nuvoton NPCE386 EC/KBC.
A: The BIOS is a 16MB Quad Read SPI Flash ROM.
A: The board uses DDR4 3200MHz memory in a memory-down configuration, with four pieces per channel for both Channel A and Channel B.
Q: What charging IC is used?
A: The charging IC is a BQ25700ARSNR.
Q: What audio codec is present?
A: The audio codec is a Realtek ALC3287.
  • Lenovo Flex LC55-14A 19793-1 Schematic.pdf
