Lenovo Flex 2-14d - LF145M MB - 13287-1 - LF155M 13310 Schematic
The Wistron LF145M-1 motherboard, project code 4PD00Y010001 and PCB number 13827, is built around the AMD Beema UMA/PX platform featuring an AMD Beema FT3b APU with integrated AMD GPU Jet-1 graphics supporting DX11, eDP, HDMI, and VGA DAC outputs. The system uses a single-channel DDR3L memory architecture with one DIMM slot. Power management is handled by a BQ24715RGRR PWM charger IC and multiple DC/DC converters including ISL62771HRTZ-T, SY8208DQNC, RT8207MZQW, RT8068AZQW, and RT9025-25ZSP. The embedded controller is an NPCE285GA0DX, and the audio codec is an ALC233. Connectivity includes an RTL8106E LAN IC, GL3213 card reader, and WLANs Bluetooth module. The board also features an SPI flash for BIOS storage and an LTDP1 HDMI level shifter.
A: The embedded controller is an NPCE285GA0DX.
Q: What charging IC and architecture does this board use?
A: The charging IC is a BQ24715RGRR, and the charger architecture is PWM.
Q: What is the memory configuration of this motherboard?
A: The board uses a single-channel DDR3L architecture with one DIMM slot.
Q: What LAN and card reader ICs are present?
A: The LAN IC is an RTL8106E, and the card reader IC is a GL3213.
| Model | LF145M-1 |
| Project Code | 4PD00Y010001 |
| Board Number | 13827 |
| Revision | A4 |
| Date | Tuesday, February 18, 2014 |
| CPU Platform | AMD Beema UMA/PX |
| CPU Model | AMD Beema FT3b |
| GPU Type | AMD GPU Jet-1 |
| Graphics Architecture | DX11, eDP (X1), HDMI (X1), VGA DAC |
| EC / KBC | NPCE285GA0DX |
| Audio Codec | ALC233 |
| Charging IC | BQ24715RGRR |
| Charger Architecture | PWM |
| Power IC(s) | ISL62771HRTZ-T, SY8208DQNC, RT8207MZQW, RT8068AZQW, RT9025-25ZSP |
| RAM Type | DDR3L |
| RAM Quantity / Slots | 1 DIMM |
| Card Reader IC | GL3213 |
| LAN IC | RTL8106E |
| WiFi / WLAN IC | WLANs Bluetooth |
| HDMI Level Shifter | LTDP1 |
4PD00Y010001
13827
Beema
PX
AMD Beema FT3b
GPU Jet-1
NPCE285GA0DX
ALC233
BQ24715RGRR
ISL62771HRTZ-T
RT8068AZQW
RT8207MZQW
RT9025-25ZSP
SY8208DQNC
DDR3L
GL3213
RTL8106E
LTDP1
4PD00Y010001
13827
Beema
PX
AMD Beema FT3b
GPU Jet-1
NPCE285GA0DX
ALC233
BQ24715RGRR
ISL62771HRTZ-T
RT8068AZQW
RT8207MZQW
RT9025-25ZSP
SY8208DQNC
DDR3L
GL3213
RTL8106E
LTDP1
