lenovo e40 e50 ld-note gc5-dis-c-stage 1103 schematic 1
This Quanta LD-Note Calpella Discrete motherboard is built on the Intel Calpella platform with an Arrandale CPU in an rPGA 989 socket and an Ibex Peak-M Intel 5 Series PCH. Graphics are handled by a discrete AMD M92-S2 XT GPU. The system uses an ITE8502 EC/KBC in an E48 package, an ALC269 audio codec, and an RTL8111DL LAN controller. Memory configuration supports dual-channel DDR3 800/1067 at 1.5V across four SODIMM slots. The BIOS SPI flash is a 2Mbyte device. Power management is handled by multiple ICs including the MAX17101, TPS5116REGR, RT8204, MAX17082, MAX8792, and OZ8116LN. A MAX6694 thermal sensor and SLG8SP585V clock generator are also present. The board includes an RTS5159 card reader, R5538 USB hub, and G993P1U fan controller.
A: The motherboard uses an ITE8502 EC/KBC in an E48 package.
A: The BIOS SPI flash is a 2Mbyte device.
A: The board supports dual-channel DDR3 800/1067 at 1.5V across four SODIMM slots.
| Project Code | LD-Note Calpella Discrete |
| Document Number | 1122334455667788AABBCCDD |
| Revision | A3 |
| Date | Tuesday, November 03, 2009 |
| CPU Platform | Intel Calpella Platform with Discrete GFX |
| CPU Model | Arrandale |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | Ibex Peak-M Intel(R) 5 Series Express Chipset |
| GPU Type | Discrete GFX AMD M92-S2 XT PCIEx16 |
| Graphics Architecture | Discrete VGA (M92-XT) |
| EC / KBC | ITE8502 |
| EC/KBC Package | E48 |
| Audio Codec | ALC269 |
| BIOS / SPI Flash | FLASH 2Mbyts |
| BIOS Flash Capacity | 2Mbyts |
| Charging IC | BATTCHARGER |
| Power IC(s) | MAX17101, TPS5116REGR, RT8204, MAX17082, MAX8792, OZ8116LN |
| RAM Architecture | Dual Channel DDR3 800/1067 1.5V |
| RAM Quantity / Slots | DDR3 x 4 (256M/512M), DDR3 - SODIMM0, DDR3 - SODIMM1 |
| Card Reader IC | RTS5159 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | WLAN/WiMAX |
| Thermal Sensor | MAX6694 |
| Clock Generator | SLG8SP585V (QFN32) |
| USB Hub IC | R5538 |
| Fan IC | G993P1U |
| Accelerometer | Accelerometer (APS) |
Calpella
Arrandale
989
IT8502
ALC269
MAX17082
MAX17101
MAX8792
OZ8116LN
RT8204
TPS5116REGR
RTS5159
RTL8111DL
MAX6694
SLG8SP585V
R5538
Calpella
Arrandale
989
IT8502
ALC269
MAX17082
MAX17101
MAX8792
OZ8116LN
RT8204
TPS5116REGR
RTS5159
RTL8111DL
MAX6694
SLG8SP585V
R5538
